Pics of My DFH
Set up is Ls/vtec
81.5 11.8 Compression pistons
eagle Rods
I/H/E
Soon to have a type R Head
Car weighs in at 2280 with Gun Metal Hx wheels.
Strictly an all motor bandit.... Reaching for the 12's on street tires.
Also suspension is Adjustable Kyb's in the rear non adjustable in the front with Sprint Integra Spring Rates That lower the car 1.9 inches.
[Modified by Camber, 5:26 AM 6/9/2002]
eagle Rods
I/H/E
how did you fit the hx wheels on the si hubs....i had hella people complaining that they dont bolt on , or dont fit the hub....
Int he front side of the caliper there is a support bracket that needs to be grinded a little not much. Just do it till the wheels no longer rub. I did it with a dremmel tool on one set of hubs and a grinder on the other set.... witht he grinder it too me 2 mins
Hx wheels are lighter they only weigh 11.7lbs without tires...... Thats why they are on there i recently went from the Gunmetal ones to The stock colored hx wheels... Pictures will be up soon of mine and rain man ek's car together. TWO bad *** eks.
Set up is Ls/vtec
eagle Rods
I/H/E
eagle Rods
I/H/E
How long have you had the LS/Vtec setup? What head are you running on it now? Who built it?
NALGAS!
