code 15 no start and other q's bout 90 si to 89 si becuase of hacked harness
this happened a long time ago. . . .what does it mean and where is it. . . .
anyways it was in my first swap. . . .90 si with a butchered harness. . . .
so i ordered a 89 si harness interior harness, tails, gauge cluster, dash harness. . .
will i run into any problems?
and how do i fix code 15 anyways?
code 15 is the igniter - either the igniter is bad or something wrong in your wiring - the harnesses should be o.k. as long as one of them isn't an HF harness
yea it's from an 89 si hatch or so i was told and now i just need the dash harness and i should be good to go. . . . .
the igniter in disty or what. . . because i wasn't getting anything just crank and no spark. . . .but i put in two good used disty's and then when i swapped one of the engines back into the teggy it ran fine. . .
hence buying a new harness
EG6_LS_BOOST
Feb 13, 2013 05:32 AM
1990whitecrx
Sep 26, 2010 10:10 AM
catchthis92hatch
12
May 4, 2007 10:50 PM
