skipping gear
what happen when your on 2nd gear and jump to the 3rd then you have to stop. so you shift right to nuetral then when you go you shift to the 1st or 2nd gear and go. since you did that would it mess up the gear box or the transmission? well basicly you jump from third to nuetral then to first or second gear.
From: Why To Steal My Car, NC, United States Of America
not bad but depends on the speed your going into you never want to put it into first gear when moving only when at a dead stop put it in 2nd or 3rd depending what speed your going and what rpm ur at
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 »</TD></TR><TR><TD CLASS="quote">not bad but depends on the speed your going into you never want to put it into first gear when moving only when at a dead stop put it in 2nd or 3rd depending what speed your going and what rpm ur at</TD></TR></TABLE>
thx cause i would think that itll mess up the transmission or the gear box. thx though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 »</TD></TR><TR><TD CLASS="quote">just remeber never go in 1st gear if car is moving you cud mess up the shift forks in the tranny</TD></TR></TABLE>
... all you have to do is shift to neutral, let go of the clutch, rev match to whatever rpm you'd be going at that speed in first, put the clutch in, and put it in 1st. it'll go in just fine. you never want to force it in, though, that's true.
and i think if you do force it in it'll just wear out the syncros faster
