B20 W/ LS Tranny
Old Jul 12, 2007 | 12:12 AM
Simmerman's Avatar
Default B20 W/ LS Tranny
I'm running a B20 w/ LS tranny.
When I go to order my clutch I am going to order it for a LS correct?
I just want to make sure before I get pissed for ordering the wrong one.
thanks.
Old Jul 12, 2007 | 04:49 AM
b18LS's Avatar
Default Re: B20 W/ LS Tranny (Chirp)
I think I'd use the B20 clutch, I might be designed to handle slightly higher torque output. I think either would fit though, I know other B series clutches are interchangeable. I had a B16 clutch when I had my LS tranny/B16, then used the same clutch when I went to the J1 tranny. good luck
Old Jul 12, 2007 | 06:11 AM
4g hatch's Avatar
the 90-91 trannys have less teeth on the main shaft any thing newer has the same amount. what flywheel are u using some of the bolt patterns for the pressure plate i think are different but im not positive on that one
Old Jul 12, 2007 | 07:22 AM
Simmerman's Avatar
Default Re: (4g hatch)
It's a 97 B20 w/ a 95 LS tranny.
Old Jul 12, 2007 | 08:54 AM
4g hatch's Avatar
when i call ask if they are the same part #. since your tranny is newer than 91 i would just order the b20 so u know u get the right pressure plate for your flywheel
steviecrx
Transmission & Drivetrain
Nov 3, 2011 10:34 AM
doct3rj
Mar 21, 2007 09:03 AM
Itzmy91Teg
Jun 9, 2006 11:49 AM
kmf0211
Aug 3, 2005 08:41 PM
superintegra
May 20, 2004 03:40 PM
