drilled/slotted rotor question
is there a certain way the slots need to be angled?for example I have gsr blade rims on my car.should they be the smae angle of the rims liek on the driver side or should they be angled like the passenger side?I have it angled like on the passenger side but im just double checking.thanks
Modified by 808jdm_profileEG6 at 4:47 PM 7/12/2007
Hi not sure what you mean. The slots spiral outwards as far as I know to dissipate heat. If you had them th other way around it would trap it.
Here is what Brembo has to say about the issue.
The vanes in the middle of the rotor determine which side of the car the rotor should be mounted. If the vanes in the rotor are not directional, then go by the direction of the slots like Brembo has outlined.
So, they would face like the direction of your blades on the drivers side, but if you look at the blades on your passenger side, they are opposite than what the slots on the rotor would be.
Brembo also says that they believe the outside edge of the slot should make contact with the brake pad first, just like the diagram.
Modified by Sam92Teg at 10:14 AM 7/13/2007
