jdm b16a, lots of questions..
I just bought a 94 hatch with a jdm b16a in it. It was converted to a hydro tranny. But my slave cylinder and clutch master cylinder is leaking. What car do I get these parts from?What year too? I keep having to put brake fluid in reservior every 3 days or so. Also someone looked at it and told me my pcv set up is misssing a few parts, and throttle body not closing... I dont know how to post a pic to show it. any help would be greatly appreciated. What mods can I do to make more power, it has a CAI and full catback exhaust already...
You will need a clutch slave cylinder and clutch master cylinder for a 94 civic with a manual transmission. Any civic 92 and up with a manual transmission is hydraulically operated. 91 civics and older with a manual transmission are cable operated. Im pretty sure you can get these parts from autozone or hondaautomotiveparts.com. If you cant get them there, go to a junkyard. Hope this helps. Id go into more detail but Im pressed on time right now.
Cool Cool Island Breezes. BOY-EE
your 94 wasnt converted to hydro. it was hydro when it left the factory. Get the parts for a 94 car. I think the D series slave cylinder will fit a B series. If not, then your safest bet would be a 99-00 Si slave cylinder.
If your throttle body isnt closing all the way, adjust your cable. If the cable isnt out of adjustment, check the stop screw. If everything is in adjustment, try cleaning it with some SENSOR SAFE throttle body cleaner.
If your PCV valve is broken...get a new one. Either the 99-00 Si part..or if it makes you feel cuddly, the ITR part. Same goes for the PCV hoses.
nefariousyellow
Dec 15, 2007 11:57 AM
