my car doesnt start (fuel problem)
90 crx si
new fuel pump
new fuel filter
2 different relays tried
it sounds like it wants to start, but doesnt i cant figure out why it doesnt get enough fuel is there something like a solenoid valve that would be blocking it
what are some reasons i wouldnt be getting enough fuel
new fuel pump
new fuel filter
i dont think the relay clicks i put a different one in like i said and that one didnt work at all so i put the other one back in the pump is good, i put one in myself and it didnt work, so i had a mechanic install one, expensive one too. and it pumped good from minnesota to california. what lines are you talking about, the fuel lines from the tank?
well if ur relay aint clickin somethin is wrong it should be clickin as soon as you turn the key on... try turning the key on then lightly hittng it then see if it clicks cuz it should be,,,, ya maybe there on the wrong way like output>rerurn ... may be its ur injectors try switchin ur injector resistor box or maybe even the inj.s them selves.. it is Si right?
StegRX
Feb 8, 2016 07:54 AM
