Will civic si struts and springs fit an LS integra?
Old Jul 11, 2007 | 06:14 PM
hondajunior's Avatar
Default Will civic si struts and springs fit an LS integra?
I guess you're wondering why not upgrade instead using civic struts on an integra.
well the answer is simple. I'm POOR. I have a 96 integra. when i bought my car it already had a set of after market struts and spring on it. well... it's really just after market junk! all of them are completely blown. Anyways. I found a set of struts off of a 2000 civic si. just wondering will it fit the integra!? it's free!!!
Old Jul 11, 2007 | 06:20 PM
99DCteG's Avatar
Default Re: Will civic si struts and springs fit an LS integra? (hondajunior)
no but from 92-95 civic they will
Old Jul 11, 2007 | 06:28 PM
Dogginator's Avatar
Daisy... Daisy...
Yes, they will fit. (Koni has the same p/n for a 2000 Si and a 94-01 non ITR Integra.)
http://www.koni-na.com/
BTW: they are shocks, not struts.
Old Jul 11, 2007 | 06:31 PM
99DCteG's Avatar
Default Re: Will civic si struts and springs fit an LS integra? (99DCteG)
oops i stand corrected
Old Jul 11, 2007 | 06:58 PM
Jtuned DC2's Avatar
* B A N N E D *
yep. Just the Si shocks dont have brackets for the brake lines to bolt on to so.. you would have to zip tie them.
Old Jul 11, 2007 | 07:04 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (KevLo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevLo &raquo;</TD></TR><TR><TD CLASS="quote">yep. Just the Si shocks dont have brackets for the brake lines to bolt on to so.. you would have to zip tie them.</TD></TR></TABLE>
You can swap the brackets.
Old Jul 11, 2007 | 07:25 PM
Sumslapper's Avatar
Year 3030
Default Re: (Dogginator)
i thought only the fronts fit because the rear LCA's on 96-00 civic's were smaller and they wont fit over the rear LCA's on 92-95 civic or 94+ integra.
Old Jul 12, 2007 | 03:03 AM
this is great news thanks guys!
Old Jul 12, 2007 | 04:31 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Sumslapper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sumslapper &raquo;</TD></TR><TR><TD CLASS="quote">i thought only the fronts fit because the rear LCA's on 96-00 civic's were smaller and they wont fit over the rear LCA's on 92-95 civic or 94+ integra. </TD></TR></TABLE>
You are correct. I looked only at the fronts. The rears are different.
Old Jul 12, 2007 | 02:25 PM
rears don't fit huh.... boo... that sucks...
Old Jul 12, 2007 | 10:13 PM
lsvtek's Avatar
Default Re: (hondajunior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondajunior &raquo;</TD></TR><TR><TD CLASS="quote">rears don't fit huh.... boo... that sucks...</TD></TR></TABLE>
not true. I got a set of tokico shocks rears that came off a civic si. Fit in perfect with no problem. people had been saying it wouldnt fit, but it fit. Both front and back fit with no problem. Just in the front, the brake lines wouldnt attach because there isnt a bracket there
Old Jul 13, 2007 | 06:13 AM
vladd's Avatar
Default Re: (LSintegra4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSintegra4 &raquo;</TD></TR><TR><TD CLASS="quote">
not true. I got a set of tokico shocks rears that came off a civic si. Fit in perfect with no problem. people had been saying it wouldnt fit, but it fit. Both front and back fit with no problem. Just in the front, the brake lines wouldnt attach because there isnt a bracket there</TD></TR></TABLE>
integra lca's are wider than the 96-00 civic lca's. your tokicos must've been made for the 92-95 civic/94+ integra. like someone else already said, the front brake line brackets can be removed from the stock shocks and put on aftermarket ones.
Old Jul 13, 2007 | 01:24 PM
Sumslapper's Avatar
Year 3030
Default Re: (vladd)
i will try to make this as clear as possible so there is no confusion. If you notice, most aftermarket shock company's will advertise there shocks to fit 92-00 civics and 94+ integras.
As far as i know, there was never a aftermarket shock made specifically for 96-00 civics. the company's provide you with spacers/washers for the rear shocks for 96-00 civics to fit properly over the skinnier rear lca's. this is why the tokico's fit with no problem for user lsintegra4
since the shocks came off a 99 si and they are stock, they were only meant for that model or any 96-00 civic at that.
Old Jul 13, 2007 | 01:41 PM
lsvtek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sumslapper &raquo;</TD></TR><TR><TD CLASS="quote">i will try to make this as clear as possible so there is no confusion. If you notice, most aftermarket shock company's will advertise there shocks to fit 92-00 civics and 94+ integras.
since the shocks came off a 99 si and they are stock, they were only meant for that model or any 96-00 civic at that. </TD></TR></TABLE>
oh, maybe thats why they fit with no problem. I remmeber I asked the same question, but people said it wouldnt fit. then when I got them, it fit perfect
Old Jul 13, 2007 | 01:49 PM
we shall find out tomorrow guys!
Old Jul 13, 2007 | 03:03 PM
PLAGUED_DB7's Avatar
It will fit...Nothing a grinder, and a hammer cant fix
Old Jul 15, 2007 | 03:51 AM
well heres the verdict! only the front fit... the rear doesn't fit.
the front is weird. i don't know if it's me or what, but after installing the front it looks like my integra can go off roading! haha maybe i'm exaggerating a bit, but it does look like it gave it more clearance.
it doesn't ride too bad. Now all i need so to find a set of rear shocks.
thanks for you input guys.
Old Jul 15, 2007 | 04:37 AM
DC2R_JOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondajunior &raquo;</TD></TR><TR><TD CLASS="quote">well heres the verdict! only the front fit... the rear doesn't fit.
thanks for you input guys.</TD></TR></TABLE>
Yeah thats Because civic struts sit Higher! If you put your old strut side by side with the civic one you'll see what I mean
Old Jul 15, 2007 | 12:20 PM
vladd's Avatar
that's exactly what several people have told you. the integra rear lca IS thicker than the 96-00 ciivc.
Old Jul 15, 2007 | 12:35 PM
well i had to give it a try anyways... i mean why not it was free
78CITYTURBO
Classic Hondas
Nov 12, 2009 04:59 PM
rotascircuit
Mar 10, 2008 10:44 PM
lsvtek
Dec 18, 2006 02:37 PM
95greenteg
Aug 24, 2004 04:17 PM
