Car sits werid on H&R's and KYB AGX's
for some reason my car dosent sit as low as i want it to. I have H&R's and KYB AGX's and it seems like it sits to high in the back, unless thats how it is susposed to sit. Ive seen other people with H&R's and it seems like theres sits better. Any one have anypictures of there tegs on H&R's. Or any suggestions?
that is one clean *** gsr. i hope you dont park it there overnight.
h&r sport springs? looks like it. did you just put them on? springs kinda have to "settle"in. and what are your settings at on the KYBs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR »</TD></TR><TR><TD CLASS="quote">that is one clean *** gsr. i hope you dont park it there overnight.
h&r sport springs? looks like it. did you just put them on? springs kinda have to "settle"in. and what are your settings at on the KYBs?</TD></TR></TABLE>
thanks man, and no i dont park it there over night, i usally park it in a garage. But yea the springs are old they were on the car when i bought it with stock shocks. I recently put the KYB's on a month or so ago, along with the rims. Im not sure if the sport springs and the race srpings are different colors but mine are a drak blue alomost black color.
Here is a pic of mine on stock shocks and H&R springs. They were put in 2000 by the original owner(I'm 2nd) when he first got the car and the car is pretty stiff to my surpirse still to this day. The only difference between mine and yours is that my back end is a little bit lower.
Yep, looked like mine did when I put H&R's on my Konis. More gap in the rear than in front. Luckily I was able to lower the rear spring perch on the Konis to even it out.
Also, you should pre-load your bushings now instead of waiting for it to "settle" and tear the bushings. It might actually be a touch lower if you pre-load the bushings. Loosen all the LCA, UCA, and lower shock mount bolts with the car on jack stands, then use a jack to raise each LCA up to where that corner lifts off the jack stand, then tighten the bolts to spec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Yep, looked like mine did when I put H&R's on my Konis. More gap in the rear than in front. Luckily I was able to lower the rear spring perch on the Konis to even it out.
Also, you should pre-load your bushings now instead of waiting for it to "settle" and tear the bushings. It might actually be a touch lower if you pre-load the bushings. Loosen all the LCA, UCA, and lower shock mount bolts with the car on jack stands, then use a jack to raise each LCA up to where that corner lifts off the jack stand, then tighten the bolts to spec.</TD></TR></TABLE>
alright ill try that, any one else have any suggestions?
drag springs? Only if you want your car to sit higher in the back and be unbearable to drive on the street because of the insanely high rear spring rate.
If you really want to even it out, I would suggest Ground Control coilovers on Koni Sport shocks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ()()DC2 »</TD></TR><TR><TD CLASS="quote">i have H&Rs and i dont like them at all!!! </TD></TR></TABLE>
Me either, mine dropped my car 2+" and were way too soft to be that low.
see the back of yours sits lower than mine does, and thats how i want mine to sit. What size wheels and tires are you using. Could that be a problem? I still cant figure it out??
Are you going for looks or performance...? There is a real big difference in the way the car will sit. I set my gsr up for autocross and track, if your car is too low it will be harder to transfer the weight. Also, i like the front lower than the back for looks, but for performance the back should be a little lower to sift the CG more towards the center of the car. But if you just want to go for looks set it how you want it, and drive.
well im not saying its susposed to sit lower than the front, im just saying i think it should sit lower than it is now.
and thank you for the compliments.
