main and rod bearing questions......
Old Jul 11, 2007 | 06:53 AM
young noob's Avatar
Default main and rod bearing questions......
hey guys, i have a d16y7 block that i bored .040 over with p29's, i am now re-assembling it, this is my first build, my question is, with all the piston kits and so-forth on ebay, they come with std, acl bearings, now when i took this apart, all the bearings looked fine, so did journals and inner rod caps and such, are honda motors typically good with the std. bearings when doing a rebuild, or are getting resized bearings a common factor when getting the oil clearance right, thanks i appreciate it
Old Jul 11, 2007 | 07:42 AM
young noob's Avatar
Default Re: main and rod bearing questions...... (young noob)
bump
Old Jul 12, 2007 | 06:19 AM
4g hatch's Avatar
use plasticgauge from any parts store in the green pack. check your repair manual to get the exact clearances. sometimes they work sometimes u need to get them sized. acl's are great bearings but only when the clearances are right. if they arent youll be taking it back apart soon
Old Jul 12, 2007 | 07:16 PM
young noob's Avatar
Default Re: (4g hatch)
thanks for the help, nice to see a fellow VA'r, ill go pick up some plastigauge, but one more question, i should buy new honda bearings.....std. ones, then check the oil clearance right? with the new bearings
Old Jul 13, 2007 | 12:33 AM
nu_B's Avatar
Default Re: (young noob)
Too my knowledge,(don't hold me to this) but your (std/stock)bearings should be fine as long as the wear on your crank journals isn't too bad/or if you've had them re-surfaced?..please really correct me if I'm wrong.
Old Jul 13, 2007 | 08:53 AM
young noob's Avatar
Default Re: (nu_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nu_B &raquo;</TD></TR><TR><TD CLASS="quote">Too my knowledge,(don't hold me to this) but your (std/stock)bearings should be fine as long as the wear on your crank journals isn't too bad/or if you've had them re-surfaced?..please really correct me if I'm wrong.</TD></TR></TABLE>
exactly, if wear is minimal to known then sure the std. bearings would be fine, its just this is my first build, and i was just wondering if the crank journals usually stay in shape or if its common to "customize" your oil clearance caz the journals have worn
Old Jul 14, 2007 | 09:41 PM
nu_B's Avatar
well firstly, get a good educated opinion on the state of your journals. Again im no expert, but wear,on a crank journal is "wear'; like gouges or lines that you can feel with your finger scratches etc.. that stuff needs to be re-surfaced.
I don't know the step ups off my memory, but i think you get like std size, then like +.030'' ."035'' etc. it just depends on how much they need to take off as they re-surface the crank. like if they take .025" off the journal right. There will be a gap between the journal and the std bearing of .025'', = no good. so the up-sized bearing will take up the rest of that space. RIGHT? I'm right, right?
Old Jul 15, 2007 | 07:13 AM
young noob's Avatar
Default Re: (nu_B)
to my knowledge, if the crank has any damage on it, it is basically ruined, or the machine shop can maybe put a new thin peice of metal over it, to give it a new smooth surface, if the crank is worn down, then that where new different sized bearings come into play for the correct oil clearance
MeathooK
Jul 14, 2008 06:23 AM
TurboKneeGrow
Mar 18, 2008 07:22 PM
TurboKneeGrow
Mar 18, 2008 02:58 PM
averyvm
11
Mar 8, 2008 01:36 PM
pumpkyn
Oct 6, 2006 02:26 PM
