Synthetic oil in transmission?
Old Jun 8, 2002 | 11:57 AM
CRXSi87's Avatar
New User
Default Synthetic oil in transmission?
Does anybody out there run synthetic oil in their transmission? Anybody know of a reason why not?
Old Jun 8, 2002 | 12:05 PM
FredoTheChimp's Avatar
Default Re: Synthetic oil in transmission? (CRXSi87)
i did when i had my accord, never heard anything about it doing anything bad.
Old Jun 8, 2002 | 03:35 PM
Malgerus's Avatar
No, in fact, car craft magazine reccomends it (even though it was a domestic t-5 tranny), so I don't see why it could hurt. If anything, it should make it smoother.
Old Jun 8, 2002 | 03:38 PM
poison's Avatar
Default Re: Synthetic oil in transmission? (89_Y_49)
yes, it makes smoothing shifter and probably life of the tranny alot longer.
Old Jun 8, 2002 | 05:30 PM
Perfectionist's Avatar
Well, since there's 3 for synth, I've got to chime in with 1 against. I tried it for a while. In sub zero weather it was great, but there was a little too much gear crunching at times. Supposedly, synth is a little too slippery for the synchros and such. I'm currently running Honda MTL, and it's just fine.
Old Jun 8, 2002 | 05:43 PM
Urban Business
Guest
Posts: n/a
Default Re: Synthetic oil in transmission? (Perfectionist)
<-- uses synth trans fluid
Old Jun 8, 2002 | 09:26 PM
Mista Bone's Avatar
D Tranny Guru
syn. tranny fluid = goodbye synchros!!!!!
The synchros NEED some friction to work.
Old Jun 8, 2002 | 09:38 PM
MrTodd's Avatar
Default Re: Synthetic oil in transmission? (Mista Bone)
Screw all this other synthetic junk. I used everything (mobil 1 motor oil, redline mtl - cuz I'm an idiot) then everybody told me to drain that redline crap cuz it sucks, and put in the Honda MTL. It works wayyyyy better than anything else. Think about it, honda designed those trannys, and now they have an oil that is made specifically for those trannys. Anybody that doesn't have Honda MTL in their tranny doesn't know what their doing - it's that simple.
BTW: if you're still obsessed with 'synthetic' oil, then you'll be happy to know that the Honda MTL is part synthetic as well...
Old Jun 8, 2002 | 09:41 PM
HF2ZC's Avatar
I'll second Mr. Todd's reply, definitely use Honda MTL. If you are going to use something else, use regular 10w30 motor oil, but do not under any circumstances use synthetic motor oil in your transaxle.
Old Jun 9, 2002 | 10:33 AM
Malgerus's Avatar
Default Re: Synthetic oil in transmission? (HF2ZC)
When I asked the Honda dealer for MTL, they said "It's the same stuff as regular motor oil" and told me it wasn't worth the price. they recommended 5w30 motor oild. I now use castrol gtx 5w30 and it feels fine!
Old Jun 9, 2002 | 11:40 AM
crxzc's Avatar
it sounds like no one is really sure on what oil is best for a honda tranny. i have gone through a few tranny swaps and tried different oil each time. chiltons crx manual recommends honda MTL or 10w-40. most honda's third gear grinds because of worn sincros. 5W-30 oil will make your tranny loud but does the job.
Old Jun 9, 2002 | 02:17 PM
Doctor CorteZ's Avatar
MTF only , my 3rd / 4th grinds were only from syn. oil in the trans
IT IS too slipery , MTF only
Old Jun 9, 2002 | 03:31 PM
Jesse H's Avatar
Just based on smell alone I can tell honda MTL isn't the same as motor oil.
Old Jun 9, 2002 | 05:58 PM
*Boostwerks*'s Avatar
Honda MTL Cheeper then redline too.
Old Jun 21, 2002 | 10:07 PM
crxzc's Avatar
what is all this about honda MTL. i have never heard of honda MTL in my Life. the only type of tranny oil honda has is MTF (manual transmision fluid) and ATF (automatic transmision fluid). just saying
Old Jun 21, 2002 | 10:18 PM
Default Re: Synthetic oil in transmission? (crxzc)
It mean's the same thing.
Some people just call it Fluid(what it should be called) instead of "Liquid" as honda put's it.
Old Jun 22, 2002 | 07:17 AM
rioninja's Avatar
Honda MTF/L IS part synthetic.
Old Jun 22, 2002 | 07:46 AM
Kasper.'s Avatar
Default Re: Synthetic oil in transmission? (RioNinja)
you can get that at the dealer right? I need a tranny change/fluid bad my 3rd gear grinds and somtimes its a lil harder to get into gear im sure it will feel a lil better with a tranny fluid change. hey off the top of everyones head where is the tranny fluid drain bolt? I havent looked but while were on the subject figured Id ask?
Old Jun 22, 2002 | 08:29 AM
crxzc's Avatar
Default Re: Synthetic oil in transmission? (Kasper 1)
whatever, screw honda MTF tranny oil. just go and get some 10w-40 oil at the store for a lot cheaper and it will do the same thing. i paid $4.80 a quart for honda tranny oil and it didn't work any better then the old oil i had in it before.
Old Jun 22, 2002 | 09:11 AM
spettinger's Avatar
the drain will be on the very bottom of the trans case, you will see a 3/8 square opening where you put a ratchet with no socket to open it.
Old Jun 22, 2002 | 12:37 PM
bryant's Avatar
Default Re: Synthetic oil in transmission? (hondaslut #042)
Honda MTF =
rEnZ94tEgGy
Jul 20, 2008 12:30 PM
Lucas_pln
Apr 17, 2007 06:06 AM
kixcrx
21
Dec 29, 2006 04:38 PM
meagainsttheworld
40
Sep 5, 2006 02:52 PM
Mario.
Mar 24, 2004 10:06 AM
