so i expierenced brake fade yesterday
Old Jun 8, 2002 | 11:41 AM
CD8's Avatar
CD8
Default so i expierenced brake fade yesterday
for the first time... i had to do a lot of running around yesterday in the 110+ degree heat. towards the end of the day, i had mad brake fade yo! so this is my question... was it the pads/rotors heating up(this is what i think) or was the fluid begining to boil? so you know, all pads/rotors are oem.
im not planning on doing and brake upgrades for a long time, i guess i just really wanted to know what was fading... the pads right?
Old Jun 8, 2002 | 11:58 AM
Nick H's Avatar
New User
Default Re: so i expierenced brake fade yesterday (exaccord)
yes it was the pads and possibly the rotors...i don't think the fluid was boiling (but maybe it was ???) this will happen no matter what when you are in really hot temperatures...just don't do any heavy braking and you should be ok!
Old Jun 8, 2002 | 01:56 PM
Gennady's Avatar
New User
Rotors were hot, pads were overheating, fluid was coming close to its respective wet and dry boiling points.
Old Jun 8, 2002 | 02:48 PM
CD8's Avatar
CD8
Default Re: so i expierenced brake fade yesterday (Wont be beat)
you guys think i should bleed the system just in case it boiled a lil bit?
my dad thinks i should just flush out the system and put new fluid because i have never done that as long as ive had the car any, so now is as good as time as any.
[Modified by exaccord, 3:49 PM 6/8/2002]
Old Jun 9, 2002 | 10:23 AM
4doorH22's Avatar
What pads were you using?
It was probably the fluid and yes you should bleed if you haven't in a while.
Old Jun 9, 2002 | 10:25 AM
4doorH22's Avatar
Holy **** yes you should do a full bleed and put some good **** in there. Try and get ATE super blue or ATE Gold Type 200 or Motul RBF 600.
Old Jun 9, 2002 | 10:44 AM
Kazmans94cord's Avatar
Default Re: so i expierenced brake fade yesterday (4doorH22)
can you get this at like AutoZone or a place like that?
Old Jun 9, 2002 | 11:41 AM
4doorH22's Avatar
Default Re: so i expierenced brake fade yesterday (kazmans94cord)
Probably not. A chain called Olympic Auto Parts around here carries ATE. A more specialized auto parts store (maybe even NAPA?) or speed shop should carry it. You can probably find Motul at a motorcycle shop/dealer.
Old Jun 9, 2002 | 12:23 PM
sweetness...thanks dave ill check it out
Old Jun 9, 2002 | 01:38 PM
CD8's Avatar
CD8
yeah, thanks dave!
Old Jun 9, 2002 | 06:27 PM
Gennady's Avatar
New User
If you need a high performance fluid that a major chain carries which is also cheap, try Valvoline Synthetic Synpower (I think thats what its called). It is sold at Pep Boys and costs $7.99 per bottle. 2 bottles are enough for a flush.
Old Jun 10, 2002 | 04:34 AM
smokin rubber's Avatar
You probably only faded the pads but if you havenot changed out the fluid do a complete flush, I use the valvoline syn. You can not fade a rotor, nope.
digam100
Suspension & Brakes
12
Nov 19, 2017 06:07 AM
davemem
Honda CR-V & Element
Dec 12, 2010 07:44 AM
clement_h
May 15, 2003 12:39 PM
harryg
Jul 15, 2002 06:04 AM
ActiveAero
Mar 21, 2002 08:33 PM
