Hissing noise from evaporator when A/C on in EM1
Old Jul 10, 2007 | 01:32 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Hissing noise from evaporator when A/C on in EM1
I've recently noticed a hissing noise coming intermittently from my evaporator when I have the A/C on and am wondering if anyone knows the cause. My idle also seems to bog down at idle then go back to normal when the compressor kicks on; it seems like it does this more than it should. The A/C blows cold with no problems.
Here's what I think it may be:
1.) Low refrigerant level
2.) Expansion Valve
3.) I need a new drive belt or it needs to be tightened.
Any input would be appreciated. This is a completely stock system in a completely stock 99 EM1.
Old Jul 10, 2007 | 03:49 PM
slowcivic2k's Avatar
Default Re: Hissing noise from evaporator when A/C on in EM1 (wiZCo)
See if you can determine it to be a internal hiss, there is a pressure relief valve in the system to prevent over pressurizing the refrigerant, that could be the cause. I would check your refrigerant pressures with a gauge to see if you are overfilled or underfilled, A/C work is not cheap.
Compressor kick-on time is usually for 10 secs or so, with a 5 sec down time, and then back to work it goes.
Old Jul 11, 2007 | 12:19 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Hissing noise from evaporator when A/C on in EM1 (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">See if you can determine it to be a internal hiss, there is a pressure relief valve in the system to prevent over pressurizing the refrigerant, that could be the cause. I would check your refrigerant pressures with a gauge to see if you are overfilled or underfilled, A/C work is not cheap.
Compressor kick-on time is usually for 10 secs or so, with a 5 sec down time, and then back to work it goes.</TD></TR></TABLE>
Good stuff, I was going to check the pressure on the lines anyways to be sure. Thanks!
Old Jul 30, 2007 | 01:12 PM
wiZCo's Avatar
Stouts 'n' Scotch
Anybody know what the high / low pressure readings should be?
Old Jul 30, 2007 | 06:16 PM
wiZCo's Avatar
Stouts 'n' Scotch
Let me be more specific, it kind of sounds like water bubbling and steaming and I know it's coming from the evaporator.
I'm thinking bad expansion valve or low coolant. Air is now not as cool as when I bought the car. I also found out that you cannot acquire refrigerant in WI without a license, so I'm prepared to get bent over to get it recharged.
Any input is appreciated.
whatmeow
Honda Civic (2006 - 2015)
Nov 28, 2018 03:31 PM
jrock1234
Jun 4, 2012 12:26 PM
dabflyboy
Honda Civic (2001 - 2005)
Jul 22, 2008 05:08 PM
AnAccordIsForever
Jul 13, 2006 11:52 AM
MaxPowerIntegra
Jul 29, 2001 01:00 PM
