i need help with my crx tranny, brakes, radiator
Ok i have a leak in my coolant box how could i fix that my radiators fans dont spin at all causing the coolant to blow thats least of my problems... i have no break fluid if i put break fluid in with out lettin the air out on my 90 crx will my line bleed? and idk for some reason i was looking at my tranny and it was really wet whats up with that please help
""Ok i have a leak in my coolant box how could i fix that my radiators fans dont spin at all causing the coolant to blow thats least of my problems...""
Fix the leak. Replace the T-stat? Maybe blown head gasket.
""i have no break fluid if i put break fluid in with out lettin the air out on my 90 crx will my line bleed?""
Huh? Again... find and repair the leak. Adding fluid won't make your line bleed. The term bleed refers to opening the lines at the wheels while applying brake pedal presure to flush and bleed the lines.
""and idk for some reason i was looking at my tranny and it was really wet whats up with that please help""
I don't know. Was it raining? Wet with what? Or just don't look at your tranny.
hondarulez
May 21, 2012 06:33 PM
crxforum
Jun 30, 2007 09:58 AM
