using afc neo trying to add a wideband o2 need help?
Old Jul 10, 2007 | 10:42 AM
dan89crxsi's Avatar
Default using afc neo trying to add a wideband o2 need help?
I am using an afc neo to tune with but i want to add a wideband o2 for better tuning i have been looking at both the aem uego and the innovate lc-1 if i have just the gauge and the o2 part can i log the air/fuel data to my laptop or do i need something extra to be able to log the data because i know with the innovate you can add the ssi-4 and log 5 sensors but i just need to know if i can log data for the afr without the ssi-4
Old Jul 10, 2007 | 11:26 AM
builthatch's Avatar
MiG-21 superfan
Default Re: using afc neo trying to add a wideband o2 need help? (dan89crxsi)
the lc1, the basic **** w/o a gauge, has stuff included to log, including a serial cable and software. i do not think the aem unit has laptop hookups available by itself. i think it's just a <5v terminal to hook into whatever system...
learn to use periods or some sort of punctuation. it will make reading your posts a little less painful
Old Jul 10, 2007 | 11:42 AM
dan89crxsi's Avatar
Default Re: using afc neo trying to add a wideband o2 need help? (builthatch)
sorry i am at work fast typing = no punctuation. anyway so i don't even really need the gauge then right? I don't see the point in having the gauge if I can log on my laptop with just the LC-1 wideband and data logging software.
Old Jul 10, 2007 | 11:47 AM
builthatch's Avatar
MiG-21 superfan
well...
the gauge is nice because you won't always have the laptop on and in the car i assume, so if you do encounter an issue while driving, ie dying fuel pump, ripped regulator diaphragm, clogged fuel filter, etc, you can hopefully see that there is a mixture issue while driving, w/o a laptop.
but you don't need the gauge, you are correct.
Old Jul 10, 2007 | 01:51 PM
dan89crxsi's Avatar
ok so the ideal setup would be my afc neo with the LC-1 wideband alongside an afr gauge
Old Jul 10, 2007 | 03:23 PM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan89crxsi &raquo;</TD></TR><TR><TD CLASS="quote">ok so the ideal setup would be my afc neo with the LC-1 wideband alongside an afr gauge</TD></TR></TABLE>
well, as much as i love Apexi, i would not suggest the NEO for tuning, BUT...
yes, that setup would work and i'd recommend using the Innovate gauge.
Old Jul 10, 2007 | 04:41 PM
dan89crxsi's Avatar
yeah i had planned on using something else for tuning but i was at a car club meet and my boy had a neo brand new in the box for 200$ cash so i jumped on it and decided to try it out for my ls-turbo ek
CoLoRnK
Aug 15, 2012 06:59 AM
boost and bass
Apr 5, 2009 09:33 AM
teler86
Jun 30, 2005 03:55 AM
calvarez
Jun 7, 2004 09:25 PM
Greyout
Apr 21, 2002 08:55 AM
