97 Honda Accord EX F22B Engine Swap and now sputters but will not run
Old Jul 10, 2007 | 10:14 AM
Dozzi's Avatar
Default 97 Honda Accord EX F22B Engine Swap and now sputters but will not run
My son and I put a Japan motor in our 97 Honda Accord EX with F22B. The Engine Swap required we replace the front engine cover so we could install the crank sensor and mated crank gear, throttle assy and thermostat housing. We got everything connected including all ground wires. However, the engine cranks and sputters but it will not stay running. Spark and fuel pressure is good. I think the TPS (Throttle Position Sensor) my be bad. ANYONE HAVE ANY FEEDBACK ON WHAT THE ISSUE MEYBE!
Old Jul 10, 2007 | 10:16 AM
awdgsx96's Avatar
Default Re: 97 Honda Accord EX F22B Engine Swap and now sputters but will not run (Dozzi)
Dying battery a possibility?
Old Jul 10, 2007 | 11:38 AM
dleccord's Avatar
replace your fuel pump
Old Jul 10, 2007 | 12:21 PM
Dozzi's Avatar
Default Re: 97 Honda Accord EX F22B Engine Swap and now sputters but will not run (awdgsx96)
Battery is good. Passes load test and holds a good charge
Old Jul 10, 2007 | 12:22 PM
Dozzi's Avatar
Default Re: (dleccord)
Fuel pump pressure was checked at the fuel rail and is it great. I thought it was fuel pump at first too
Old Jul 10, 2007 | 01:45 PM
awdgsx96's Avatar
Default Re: (Dozzi)
Spark plugs wires in correct order?
What about timing marks?
shinjiikarii
Jul 2, 2014 11:42 AM
dohiot
Nov 16, 2010 12:14 AM
scottdrag
Sep 4, 2008 08:55 AM
DoC-JoneS
Sep 9, 2005 01:19 PM
