Crimestopper arms but does not lock or unlock
Old Jul 10, 2007 | 10:04 AM
95excoupe's Avatar
Default Crimestopper arms but does not lock or unlock
Anyone know what I could check for this? The system arms with the remote, but it doesnt lock or unlock the doors. It's a gargoyle, not sure on the model number I could find out it if it helps, on an '03 s2000. Thanks
Old Jul 10, 2007 | 10:06 AM
B18C_EJ8's Avatar
Did it ever work or is this something that just started happening?
Old Jul 10, 2007 | 10:14 AM
95excoupe's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Did it ever work or is this something that just started happening?</TD></TR></TABLE>
Yeah it always worked, then one day it just stopped. I didn't install it either. It came with the car.
Old Jul 10, 2007 | 10:18 AM
B18C_EJ8's Avatar
Does the LED on the transmitter light up when you press buttons?
How about the LED in the car? Is that doing anything? Flashing?
Old Jul 10, 2007 | 10:21 AM
95excoupe's Avatar
The transmitter lights up. I'm not sure about the unit in the car. It's in the garage at the moment and it's gonna rain real soon. Is there a fuse I could check or something? You think thats the problem?
Old Jul 10, 2007 | 10:32 AM
B18C_EJ8's Avatar
If it arms/disarms with the remote and you can hear it chirping, then it's not going to be a fuse on the alarm...
However, if the installer used the 451M lock module when they hooked up the locks, there's a fuse on the purple wire... You could check that out, but if you see a twisted pair of wires that are blue & green, they didn't use that module...
In that case, I'd check the main ground for the alarm, and make sure it's solid, and not attached to a secondary ground in the dash somewhere...
Old Jul 10, 2007 | 11:45 AM
95excoupe's Avatar
No fuse on a purple line. No pair of blue/green wires either. I think it is just old and broken. I cant trace the ground without taking body panels off. I dont want to have a dead car either so I dont wanna move this thing around too much.
It's weird though cause if I hit the button when I have the passenger side door unlocked it unlocks the doors after 3 seconds like it used to. It seems to be working through the module, but not when I press the button.
Old Jul 10, 2007 | 11:50 AM
B18C_EJ8's Avatar
Default Re: (95excoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupe &raquo;</TD></TR><TR><TD CLASS="quote">No fuse on a purple line. No pair of blue/green wires either. I think it is just old and broken. I cant trace the ground without taking body panels off. I dont want to have a dead car either so I dont wanna move this thing around too much.</TD></TR></TABLE>
Forget what I said, because for some reason, I thought you said you had a Clifford, so I was giving you DEI colors and modules... Let me do some research on the Crimestoppers...
I would still check the ground....
Sean Juan
Honda S2000
12
Jul 3, 2008 03:22 PM
MJANGEL28
Audio / Security / Video
Apr 3, 2007 02:22 PM
Hyjnx
Sep 11, 2005 09:08 AM
bb6h22
Oct 23, 2004 11:16 AM
Thirty-Nine
Jul 9, 2003 12:45 PM
