b16a harness question
okay so i used the harness that came with the b16 and connected it. there is one plug left. square shaped. ive seen on other forums that they used their stock d series harness? im wondering if i can just use the b16 harness because everything plugs up except one plug and i think its from the dist. its a obd0 b16a and the car is 89 civic std. need help please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznjay510 »</TD></TR><TR><TD CLASS="quote">okay so i used the harness that came with the b16 and connected it. there is one plug left. square shaped. ive seen on other forums that they used their stock d series harness? im wondering if i can just use the b16 harness because everything plugs up except one plug and i think its from the dist. its a obd0 b16a and the car is 89 civic std. need help please</TD></TR></TABLE>
You may be able to use the harness that came with the engine, but you'll be rewiring the dash harness to make that work.
A picture of that plug would be helpful, but I highly doubt the harness will be easier than using your stock harness and pieces from that harness to convert the harness in the car over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznjay510 »</TD></TR><TR><TD CLASS="quote">do i still have to do the dpfi to mpfi swap?</TD></TR></TABLE>
Absolutely. Do that first, and then use the stock harness on the B16.
ElectronED9
19
Nov 3, 2009 12:22 PM
exist12
Oct 26, 2007 08:19 AM
forlorn76
May 10, 2003 01:35 AM
