OBD1 swap using d15b2 head
Old Jul 10, 2007 | 09:13 AM
HiProfile's Avatar
Default OBD1 swap using d15b2 head
I'll make the long story short, I'm planning on building another d16z6 and using it in my new sedan, but I still want to use my existing turbo kit on the d15b2. Its also autotragic atm, so it needs all the extra power it can get.
I'm thinking as long as I use the harness I used before (dpfi obd0 --> mpfi obd1), the obd1 distributor, and z6 intake mani, it should work, right? I can't recall if the z6 dizzy had the oddball mounting legs compaired to the obd0 dizzys, but I'm not afraid to do some temporary cutting I did try searching, but atm all I find is obd1/d15b2 info where the person put on a vtec head.
<U>In other words, can you do the OBD1 SWAP w/o changing the obd0 head?</U>
Old Jul 11, 2007 | 08:54 AM
HiProfile's Avatar
Default Re: OBD1 swap using d15b2 head (HiProfile)
BTW I was hoping to use my current d16z6 dizzy, not the td41 dizzy I've seen talked about.
Anyone have a suggestion? It seems the more info you put in your post, the less people want to respond...
Old Jul 11, 2007 | 12:13 PM
abnaasefmb's Avatar
get a b series, i'll sell you a used hks turbo manifold
sorry dude i don't know **** about D's
oh and pic help get people to look at your ****, so i added this one for you because it's the coolest oil distro block i ever seen.
(please don't look at this pic as it has nothing to do with anything)
carracr625
Jul 10, 2009 05:38 PM
richboi
11
Apr 17, 2006 04:36 PM
DemostheneZ
Aug 28, 2004 03:54 PM
DemostheneZ
Aug 28, 2004 02:14 PM
EARLdaSQUIRREL
May 20, 2003 11:15 AM
