spraying heat shield
Old Jun 8, 2002 | 08:50 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default spraying heat shield
how hard is it to take out the head shield? i was planning on spraying it flat black w/ high-temp paint just for the hell of it. will this work?
and if you think i'm crazy say it. i'm not thinking straight right not =P
Old Jun 8, 2002 | 09:10 AM
uNF$@#!'s Avatar
Default Re: spraying heat shield (dLo GSR)
its not hard, but takes time.
i would suggest cleaning it off with aircraft cleaner.
[Modified by 00-0187, 1:11 PM 6/8/2002]
Old Jun 8, 2002 | 09:15 AM
mantic6t9's Avatar
You're not crazy I sprayed mine and it looked really nice. On my car all i had to do was remove a few bolts and disconnect my o2 sensor. Here is a pic of mine before I got my header.
Old Jun 8, 2002 | 11:21 AM
JDM EX's Avatar
Default Re: spraying heat shield (mantic6t9)
Hey HOw you paint the black valve cover.. I want it and I dont like polish on my valve cover.. I want to paint black because most of the turbo piping are black.. I want to match the pipe and valve cover.. Tell me what kind of paint and how high the temp can handle the heat on the valve cover.. Thanks
Old Jun 8, 2002 | 12:35 PM
96 SOHC VTEC's Avatar
Default Re: spraying heat shield (JDM EX)
I just painted my headshield right on the damn header. I just covered up some parts with some towels and sprayed away. Just pic up some high temp paint at an auto store and you are set.
Old Jun 8, 2002 | 12:53 PM
mantic6t9's Avatar
here is the how to i wrote after i did mine http://www.geocities.com/mysihb/HowTo.html
Old Jun 8, 2002 | 01:53 PM
NWPNOMORE's Avatar
Banned
Default Re: spraying heat shield (96 SOHC VTEC)
damn, that's one lazy person.
Old Jun 8, 2002 | 02:00 PM
brian.edge's Avatar
Default Re: spraying heat shield (NWP4LIFE)
i painted mine the same color as my valve cover....as said above is best to use aircraft cleaner.....then go to work.....turned out prtty good
Old Jun 8, 2002 | 03:24 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: spraying heat shield (lilhibbs)
nice fuggin engine bay bro
pli
41
Feb 27, 2007 05:49 AM
cvc323
12
Nov 17, 2004 11:46 AM
RaceStyles
Nov 20, 2003 08:01 PM
IntEGNYC
Dec 28, 2002 08:40 PM
