Ls Swap to 98 HB Dx question
Old Jul 10, 2007 | 06:39 AM
HB-II's Avatar
Default Ls Swap to 98 HB Dx question
I am currently doing an Ls swap (from a 98 teg) to my 98 Dx hatch. I want to keep my current AC setup but I need a diffrent AC bracket. I heard that you can use the AC bracket of a Delsol but is there a specific year or model Del sol? Are there other brackets I can use??? Pls help
Thanks
Old Jul 11, 2007 | 07:28 AM
zerovandez's Avatar
You need to get an a/c bracket from a del sol with a DOHC engine, i forget which models. Or get one from a honda crv off the B20 engine.
They're hard to find, it took me a while to source mine.
Old Jul 11, 2007 | 04:32 PM
EKB18BPR3's Avatar
Default Re: Ls Swap to 98 HB Dx question (HB-II)
...or common sense would tell me to use one from a 99 to 00 civic si that comes with the dohc motor.
Old Jul 25, 2007 | 05:25 PM
zerovandez's Avatar
But if you knew that 99-00 si dohc motors dont use d series compressors then you wouldn't use one from an si and go with my suggestions.
because if you did, you'd have to change the compressor and recharge the system!
BigJ74
Apr 2, 2015 06:04 PM
robitjcivic
Apr 27, 2008 03:03 PM
b18bme
Apr 12, 2004 11:29 AM
hybridEj6
May 30, 2003 05:46 PM
CivicEx95
Apr 25, 2002 01:04 PM
