Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
civic electric window
Old Jul 10, 2007 | 06:18 AM
tacoma5050's Avatar
Default civic electric window
I am trying to diagnose why my 2001 Honda civic lx rear driver side electric window does not work. Here is what I discovered so far:
rear switch up: motor works/spins
rear switch down: motor does not work/spin
front master switch up: motor does not work/spin
front master switch down: motor does not work/spin
Voltages measured at the motor:
rear switch up: -12.0
rear switch down: - 0.1
rear switch neutral: - 1.3
front master switch up: - 1.3
front master switch down: + 1.2
front master switch neutral: - 1.3
With 12v applied to motor it works/spins
With reversed 12v applied to motor it works/spins opposite direction.
So it appears the motor is OK.
So what could the failing component be:
1. rear switch?
2. front master switch?
3. Is there a relay it could be?
4. something else?
Thanks....
battmancjz
Dec 22, 2015 07:15 AM
qinfujun
Jun 30, 2014 08:33 PM
rjmancia
Sep 12, 2008 09:54 AM
BlueIntegraBoy
Apr 14, 2008 10:23 PM
