starts runs and stalls.....DOHC ZC swap.....
hey need some help, i've got no clue why but my car starts, idles really shitty, and then after a while stalls. throwing codes 5 and 13... tried different ECU's, checked wiring, timing, fuses, sensors, vaccum lines....i'm stumped.
it was a straight swap from one DOHC ZC to a rebuilt one and now i have this idling thing.... any ideas?
sounds to me like it is probably vacuum related - have you checked for vacuum leaks at the intake manifold to head and throttle body to manifold? does this engine have 2 vacuum ports on the back of the intake manifold just above the EACV (A/T engine)? if so, are the capped separately or connected together? connected together will cause vacuum leak
thanks for the tip i do have them connected together so i guess i'll try the other way you suggested. i hope youre right....
B20Rex(^_^)
Dec 4, 2008 01:11 AM
