GSR Brakes and knuckle on 4dr EF?
Old Jul 9, 2007 | 09:28 PM
iMPoRT GeeK's Avatar
Default GSR Brakes and knuckle on 4dr EF?
OK i just installed a GSR Brakes and knuckle in my 89 4dr EF and now the front end looks like its jacked up and the camber is +. did I do something wrong? is the knuckle too long??? can I install the GSR caliper nad rotor on my STOCK EF knuckle? let me know how I can fix it? I was thinking about getting a camber kit and coilovers so I can slam it back down and correct the camber?
Let me know..
Thanks
Old Jul 10, 2007 | 07:13 AM
mike-y's Avatar
Default Re: GSR Brakes and knuckle on 4dr EF? (iMPoRT GeeK)
did you use 92-93 GSR knuckles or 94-01 GSR knuckles?
92-93 (DA) Knuckles work, but you need to use your civic A-arms, not the integra ones.
edit: oops 90-93 knuckles will work, not just 92-93
Modified by mike-y at 11:03 AM 7/11/2007
Old Jul 10, 2007 | 03:30 PM
x i b v r i a n's Avatar
Default Re: GSR Brakes and knuckle on 4dr EF? (mike-y)
i just recently installed 91 integra knuckles on my hf, but i also use the integra upper arms, i haven't do any allignment yet, since im using old tires (waiting when i buy new tires before i do the allignment). the car running fine for now, my question is why u cannot use the integra upper arms on ef ?
Old Jul 10, 2007 | 03:40 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">did you use 92-93 GSR knuckles or 94-01 GSR knuckles?
92-93 (DA) Knuckles work, but you need to use your civic A-arms, not the integra ones.</TD></TR></TABLE>
That is what I did.
Old Jul 10, 2007 | 07:17 PM
Its a 94-95 GSR knuckle/hub/rotor/calipers... but everything else stock... whats an "A arm" ?
Thanks
Old Jul 10, 2007 | 10:36 PM
NastyHabitzCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iMPoRT GeeK &raquo;</TD></TR><TR><TD CLASS="quote">Its a 94-95 GSR knuckle/hub/rotor/calipers... but everything else stock... whats an "A arm" ?
Thanks
</TD></TR></TABLE>keep the calipers, rotors, brakes and use the DA 90-93 knuckle. the 94-up places the balljoint in different postion.
Snailor Built
17
Nov 17, 2011 12:51 PM
tonylovesjdmEF9
18
Aug 3, 2011 08:55 PM
EfSedanLove
May 17, 2006 03:45 PM
Fred n J_v2.0
May 2, 2003 01:14 PM
