when to shift in an ls teg?
i've heard many diff. things...but where do you guys shift at when racing...is it redline everytime or do you go just before it or just before in 1st then redline in 2nd...just wondering
Off the line I shifted from 1-2 a little sooner, around 6400 or so. I only had a chance to try this once, but this run I posted my fastest time. Every other time was at 7200, and run to 7400 (holy **** stock valvetrain) in 4th so I would get through the traps without shifting into 5th with my Gsr tranny.
[Modified by 93LSivic, 4:12 PM 6/8/2002]
Smarter than you
btw, im gonna run my stock head to 7400 too. wanna take bets on who blows up first?
Get your car dynoed and look at the graph. You can asscertain a lot of info from that on when to shift and such. At least thats what I've been told.
beh....people keep saying take it to redline but there is NOOOOO power after even 6700-6800. I've been shifting at 6500 and i've gotten the best times on my Gtech (14.9) in my '92 CX. listen to the engine after ~6700...you can hear it fawking wheezing its ace off!
I've tried it at the track and my runs were always at fuel cut off. Don't bounce the rev limiter too long tho, as soon as its bouncing shift!!!
Smarter than you
keep in mind that even if the torque curve falls on its face, gearing multiplies it. which is why I'm not sure why people suggest shift early out of 1st gear. the 2nd gear ratio is about 30%-40% taller then 1st.
I suggesting shifting fast out of first just cause 1st and boost = NO TRACTION. Second isnt much better traction-wise
wuhungsixxx
Sep 12, 2002 04:00 PM
