How to remove cluster on a 1994 Honda Civic coupe?
Can someone pls provide me with the instructions on how to remove my cluster, I dont want to damage my dashboard this is why im asking for help, I tried doing it, and I broke a little bit of it. I removed the two scres from above the cluster but I cant find any other ones, Do I have to tear apart the whole dashboard? mine doesnt have a clock. how can I do it ,... thanks for any help you can give me.
FOR THE LOVE OF GOD, PLEASE NEXT TIME SEARCH USING THE SEARCH FUNCTION.
With that being said, there is another screw under your hazard switch. Remove the hazard button and you will see it. Take it out and pull out the black plastic around the cluster and center.
Then you will see the four screws holding in the gauge cluster.
Thanks a ton, I will try doing this this evening, I hope I can pull it off. oh and I know there was another post explaining word by word this, but for some reason I cant see the pictures, once again thank you very much guys.
SC2.2CL
Mar 29, 2006 11:03 AM
