ITR Flywheel Step Height?
Old Jul 9, 2007 | 10:10 AM
rallybird's Avatar
Default ITR Flywheel Step Height?
Anyone have this dimension?
Should be in the factory manual.
Stock ITR flywheel.
Almost complete with my pre-Rally West Virginia prep. http://www.rallywv.com/
http://www.max-attack.com/
JRSC
2.5" Kteller exhuast with custom metal core cat.
FAL rear window
Exedy 3 puck clutch
I'll post some pics. just need to get this clutch in!
Thanks!
Old Jul 10, 2007 | 05:05 AM
rallybird's Avatar
Default Re: ITR Flywheel Step Height? (rallybird)
Got it from Exedy.
2.6 to 2.7mm
Here's a pic. of my stock ITR clutch as installed by the factory in Japan with 98K miles mostly street, auto-x, track days, and 4 rallies on gravel and snow. Notice the broken plate. Two of the four springs were loose.
Old Jul 10, 2007 | 05:18 AM
tartje's Avatar
classic ITR clutch failure
lasted almost twice as long as mine though
Old Jul 10, 2007 | 08:12 AM
rallybird's Avatar
Default Re: ITR Flywheel Step Height? (tartje)
Comforting I guess!
Thing is I was procrastinating pulling it, because it felt fine!
So much for a 100K mile durability cycle, eh?
Old Jul 10, 2007 | 11:48 AM
Petah's Avatar
What is "step height"? Is this a clutch pedal adjustment?
Thanks.
Old Jul 10, 2007 | 12:14 PM
lev16gt's Avatar
Default Re: ITR Flywheel Step Height? (Petah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah &raquo;</TD></TR><TR><TD CLASS="quote">What is "step height"? Is this a clutch pedal adjustment?
Thanks.</TD></TR></TABLE>
I think step height is the distance from the "step" (where the flywheel bolts to the pressure plate) to the friction surface of the flywheel....and when the flywheel is resurfaced the step height should be in tolerance for whatever application.
....if that makes sense
Old Jul 11, 2007 | 08:57 AM
rallybird's Avatar
Default Re: ITR Flywheel Step Height? (lev16gt)
That's it.
98Luder
Oct 8, 2010 09:25 PM
spintboy
Dec 19, 2007 02:48 PM
SPOON_BeIgHtEeNsEe
Sep 12, 2002 03:33 PM
NVMYSi
Aug 23, 2002 06:30 AM
