What services do you perform/recommend?
When I bought my bike 2 years ago, I bought a service plan with it, so just scheduled maintenance for me. But i've done my own race baffles and gutted my cat so that was pretty handy.
But just wanted to hear about what anyone else has done, or has had experience doing when performing services to their bikes; whether the bike is newer/older from simple oil changes, doing brakes, or even tutorials on how to install aftermarket parts.
Post up.
Modified by u n v kenny at 7:35 AM 7/9/2007
Post up.
I just got my first bike in March, its a 2001 250
So far I have done the following;
Valve adjustment
Oil/filter change
Carb cleaning and adjustment
Chain Lube/Adjustment
That's it so far. I love working on a bike vs. a car just because its so much more compact (obviously) and its easier to tell what is wrong with it
So far I have done the following;Valve adjustment
Oil/filter change
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu »</TD></TR><TR><TD CLASS="quote">turials are very important</TD></TR></TABLE>
fixed
fixed
I have
re-jetted
bled brakes
installed pads
installed ss lines
installed race bodywork
removed smog crap
installed gsxr frontend onto 1st gen sv
installed PCIII USB
installed pipes
coolant flush
installed levers and rearsets
I'm missing some other stuff. I need to check my valves soon.
EDIT, added
replaced clutchmaster cycl
fender elim
flushmount signals
replaced battery
removed wheels
removed a rear shock
changed air filters
tank spacers/risers
damper install
Modified by backlash at 12:07 PM 7/10/2007
re-jetted
bled brakes
installed pads
installed ss lines
removed smog crap
installed PCIII USB
installed pipes
coolant flush
EDIT, added
fender elim
flushmount signals
replaced battery
removed wheels
changed air filters
tank spacers/risers
damper install
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u n v kenny »</TD></TR><TR><TD CLASS="quote">backlash, what kind of bike? miles? Did you buy new?</TD></TR></TABLE>
2002 SV650s and 2003 RC51
2002 SV650s and 2003 RC51. Both used. Mileage was under 4k on both if I remember correctly.
From: spinning DnB till your head explodes,jersey/philly
bandit
new pads
k+n pod filters
new tires
jetted
fender eliminator
renthals
bar end mirrors
acerbis headlight
oil changes
vfr
oil change
radiator fluid
new pads
k+n pod filters
new tires
jetted
fender eliminator
renthals
bar end mirrors
acerbis headlight
oil changes
vfr
oil change
radiator fluid
ive completly rebuilt my bike i rebuilt the engine and carbs because all honda dealers wont work on any bike over 10 years old so i do it all my self and save a lot of money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by britman »</TD></TR><TR><TD CLASS="quote">the whole idea of speedbleeders is you get no air in the system </TD></TR></TABLE>word, any particular brand you would recommend? I went to pepboys (
) and they had some brands I've never heard of
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by britman »</TD></TR><TR><TD CLASS="quote">ive completly rebuilt my bike i rebuilt the engine and carbs because all honda dealers wont work on any bike over 10 years old so i do it all my self and save a lot of money</TD></TR></TABLE>
What kind of bike did you have to rebuild? Was it an older Honda? Assuming of course.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ...rohit »</TD></TR><TR><TD CLASS="quote">word, any particular brand you would recommend? I went to pepboys (
) and they had some brands I've never heard of</TD></TR></TABLE>
I picked one up from Autozone. Works for me.
) and they had some brands I've never heard of</TD></TR></TABLE>I picked one up from Autozone. Works for me.
ive done
oil/filter
coolant flush
exhaust
levers
brake pads
brake lines
bled brakes
spark plugs
new sprockets and chain
installed speedo healer
race bodywork--fitted and painted
replaced clip ons
taken forks out
shimmed the rear
rear sets and gp sifting
removed smog crap
air filter
velocity stacks
clean and adjust chain
replaced fairing stay
cut my exhaust to make it shorty
gonna repair my race glass and make a 1/5 turn throttle next
**** ive done alot
anything my bike needs i do
heres how it sits now
oil/filter
coolant flush
exhaust
levers
brake pads
brake lines
bled brakes
spark plugs
replaced clip ons
taken forks out
shimmed the rear
removed smog crap
air filter
velocity stacks
**** ive done alot
anything my bike needs i doheres how it sits now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u n v kenny »</TD></TR><TR><TD CLASS="quote">What services do you perform/recommend?[/i]</TD></TR></TABLE>
I recommend a blow job once a week at minimum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 »</TD></TR><TR><TD CLASS="quote">
I recommend a blow job once a week at minimum.</TD></TR></TABLE>
Heeeeyyooooo!
I recomend riding and servicing when needed.
Heeeeyyooooo!
carbon removal
brake bleeding
new brake pads
replacing control cables
removal of motor
installing new bearings in block
installing new oil seals
installing new crankshaft
installing new head
installing new piston/rod
hand porting barrel
installing new reed block
installing new intake manifold
calculating squish band - installing spacers to get correct
rebuilding carb
installing new carb
jetting carb
plumbing new hydraulic systems
adding quick throttle
tire rotation
tire changes
new tubes
etc...
About everything except for paint.
brake bleeding
new brake pads
removal of motor
installing new head
hand porting barrel
rebuilding carb
installing new carb
jetting carb
tire rotation
tire changes
new tubes
etc...
OP - Did you get a service manual? That'll help out with maintenance.
Took 16 replies before someone brought this up. I think /26 is maturing....
i got one last night
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 »</TD></TR><TR><TD CLASS="quote">
pix of yer lyin'
</TD></TR></TABLE>pix of yer lyin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 »</TD></TR><TR><TD CLASS="quote">i got one last night </TD></TR></TABLE>
I got laid... I win.
I got laid... I win.</TD></TR></TABLE>
period FTL
period FTL
