testing for bent valves
Old Jul 8, 2007 | 10:06 PM
medic4.life's Avatar
Default testing for bent valves
well want to pick up motor and i want to test if its good. Im being told that i dont need to due to their 6 mo warranty. But i want to see how everything is because i want to waste my money for the parts that i paid for an engine thats no good.
Like turning that crank pulley couple of times, compression and leakdown test ill be ok ?
Also what number am i suppose to see on a compression test i know when comparing them w/ rest of the cylinders they have to be close.
Old Jul 9, 2007 | 05:58 AM
Hammer99ex's Avatar
Default Re: testing for bent valves (medic4.life)
you are correct, a leak down test would let you know the status of the valves. as for the numbers u want to see on a compression test, well, that vaies from motor to motor. whichever numbers u get, u want them to be with in 15 psi of each other
if u get poop for compression on the cylinders, try dripping some motor oil in and doing it again. if the numbers come up, your rings are shot.
spooncivic28
10
Dec 19, 2005 11:58 AM
sdinteg
Feb 1, 2005 07:52 PM
quaker
Jan 5, 2005 05:33 AM
lazyguy
May 5, 2002 01:36 PM
DR. ON POINT
Oct 29, 2001 06:38 AM
