Collector Mod ?'s & Custom Exhaust ?'s
Okay, I will be going to the exhaust shop soon, and i would like to know what parts of the down pipe needs to be replaced to make it to a 2.5 inch collector. Is it the section after the flex pipe that needs to be replaced? Or the section before the flex pipe? OR do I have to get the section where the 2 pipes meet to 1, cut? I have a MR header Heat wrapped, on a JDM H22a
Also if i remove my cat and put a 22" resonator instead with a OBX muffler, will i have black smoke coming out my exhaust while driving normally. Will it create a bad scent when driving? And is it guarantied I will have the Vtec puff of black smoke?
My car doesn’t smoke at all now but I have a CAT in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_lude »</TD></TR><TR><TD CLASS="quote">Cut it where the 2 pipes join.</TD></TR></TABLE>
If i have my cat removed or gutted out, will I have a constant carb, and gas smell during normal driving, or is it recommended to keep your cat... if you have a Daily driver
Wolfwood
Jul 25, 2005 08:32 AM
