Some naked, others not so naked (MotoGP inside)
excuse this question if the answer is unbelievably obvious but i dont know much about motogp bikes or the technology behind them, so, in the second pic, is it showing some sort of hydrolically assisted or actuated shift linkage or is some system so the rider doesnt have to use the clutch lever when switching gears?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one guy »</TD></TR><TR><TD CLASS="quote">excuse this question if the answer is unbelievably obvious but i dont know much about motogp bikes or the technology behind them, so, in the second pic, is it showing some sort of hydrolically assisted or actuated shift linkage or is some system so the rider doesnt have to use the clutch lever when switching gears?</TD></TR></TABLE>
Yes, it's a quick-shifting mechanism that allows the rider to change gears without utilizing the clutch. It senses the movement of the shift pedal and sends a signal to kill the ignition for a brief moment. This would be similar to doing a clutchless upshift by rolling off the throttle and clicking a gear....but faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy »</TD></TR><TR><TD CLASS="quote">
Yes, it's a quick-shifting mechanism that allows the rider to change gears without utilizing the clutch. It senses the movement of the shift pedal and sends a signal to kill the ignition for a brief moment. This would be similar to doing a clutchless upshift by rolling off the throttle and clicking a gear....but faster.</TD></TR></TABLE>
So when do they use the clutch?
<-- Clueless
<-- Clueless
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTi NA »</TD></TR><TR><TD CLASS="quote">
<-- Clueless</TD></TR></TABLE>
During the start. Maybe downshifts too?
From: spinning DnB till your head explodes,jersey/philly
downshifts
downshifts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZexyAccord »</TD></TR><TR><TD CLASS="quote">why does a rizzla gixxer has two pipes? one coming out of the undertail and one off to the side??? WTH?</TD></TR></TABLE>
V-4. Under the bike for the front banks, under the tail for the rear banks.
Not quite a gixxARRRR
it's a GSV-ARRRRR, so I guess that would be a gives-ARR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZexyAccord »</TD></TR><TR><TD CLASS="quote">why does a rizzla gixxer has</TD></TR></TABLE>
el. o. el....
el. o. el....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninja 6 »</TD></TR><TR><TD CLASS="quote">hot damn i love the motogp Yamahas and Hondas</TD></TR></TABLE>
Fixed. lol
Fixed. lol
The quick-shift allows for the rider to bang downshifts as well. The reason they would need the clutch in those instances is to modulate the power to the rear wheel.
Same modulation is required when starting from a stop. Otherwise unchecked, the power would loop the rider and bike in a heartbeat.
Saga Boy
Nov 25, 2008 11:37 PM
Phase2
Nov 10, 2008 10:59 AM
