EF springs/dampers on an EG
Old Jun 7, 2002 | 10:52 PM
joeseph's Avatar
Default EF springs/dampers on an EG
I know some one with good KYB struts and skunk2 coilover sleeves, both for a 88-91 crx. will they Fit on my 94 civic si?
Old Jun 8, 2002 | 09:53 AM
89civicdx's Avatar
Default Re: EF springs/dampers on an EG (jcnfh)
89-95 rear civic shocks are all the same...so if the crx rear shock is from a 89-91 crx they will fit on the back of your car.
If the rear shocks are from a 88 it won't fit...you will have to use 88 crx/civic rear lower control arms
The fronts will fit but you have to use 88-91 civic/crx front shock mounting forks
also the front shocks on 88-91 civ/crx's are about an inch shorter than the 92-95 civ fronts so it works out nicely if you lower you car.
black_89gt
Apr 23, 2012 08:13 PM
blue_hatch
Suspension & Brakes
Feb 18, 2009 08:29 PM
jdmrexx
Nov 8, 2008 05:46 PM
LudeJdm
Jun 10, 2006 05:00 PM
eghatchomar
Jan 7, 2005 07:12 AM
