piston and rod setup
Old Jul 8, 2007 | 06:46 PM
I AM WEASEL's Avatar
Default piston and rod setup
I am doing a b20vtec and I was wondering what would be a better piston and rod set up, either rs machines b20 itr pistons on shot peened b20 rods (arp bolts of course) or arias pistons on scat h beam rods? Any other combinations you would recomend - what are some b20vtec owners using?
Old Jul 8, 2007 | 10:04 PM
Old Jul 9, 2007 | 10:34 PM
Old Jul 10, 2007 | 08:22 PM
Old Jul 10, 2007 | 11:32 PM
b19coupe's Avatar
Default Re: piston and rod setup (JDM se-R)
Carillo rods, Wiseco pistons.
Old Jul 11, 2007 | 01:04 AM
Thanks, any one else want to chime in on what they think is better and giver their set up?
Old Jul 11, 2007 | 07:24 PM
Wow, this "Tech" forum is full of people who are just willing to help others out and give their opinion when it is wanted!!!!!
Old Jul 11, 2007 | 07:30 PM
Natural Aspirations's Avatar
Default Re: piston and rod setup (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Carillo rods, Wiseco pistons.</TD></TR></TABLE>
Very NICE, That is what I am running with GREAT success.
If you going cheap I say stick with the cast parts and have them well balanced and fitted. Spend the extra time/money on being picky about your tolerances/clearances.
Old Jul 11, 2007 | 08:44 PM
JDMBoostedDA's Avatar
Arias on Eagle H-Beams
Old Jul 11, 2007 | 09:47 PM
Default Re: (JDMBoostedDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMBoostedDA &raquo;</TD></TR><TR><TD CLASS="quote">Arias on Eagle H-Beams</TD></TR></TABLE>
And you would know because?
Old Jul 12, 2007 | 08:08 AM
b20beast978's Avatar
if you got teh money i would go with endyne rollerwave pistons with carrillo rods...cant get any better than that
Old Jul 12, 2007 | 05:08 PM
would you go with carrillo h-beam or a-beam? Where can you get them too?
Old Jul 12, 2007 | 08:26 PM
i cant argue with Carillo. A guy with them locally. Strongest all motor i've seen. But i ran Arias on Eagle's in my LS-Vtec about a year ago. never had a problem.
Old Jul 14, 2007 | 10:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMBoostedDA &raquo;</TD></TR><TR><TD CLASS="quote">i cant argue with Carillo. A guy with them locally. Strongest all motor i've seen.</TD></TR></TABLE>
I happen to be that local guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMBoostedDA &raquo;</TD></TR><TR><TD CLASS="quote">But i ran Arias on Eagle's in my LS-Vtec about a year ago. never had a problem.</TD></TR></TABLE>
And I know that happens to be a FLAT OUT LIE. You have never had a LS-Vtec.
Old Jul 14, 2007 | 03:35 PM
methos713's Avatar
Default Re: (Natural Aspirations)
^^oh shiet!!! But yeah, back to the subject...what about CP and Crower rods?
Old Jul 15, 2007 | 06:42 AM
sorry to jack your thread, but is it safe to run aftermarket pistons on stock rods with arp rod bolts, and vice versa?
Old Jul 15, 2007 | 07:00 AM
Default Re: (b20beast978)
After market pistons are fine to use with OEM rods, But it requires special machining of the OEM piston to use an after market rod with. Really not worth it either way. OEM/OEM or After market/After market.
allmotor99lude
Jan 4, 2006 11:37 AM
baybeboi
Oct 5, 2003 06:45 AM
Ri5e
Jul 10, 2002 08:23 PM
