Removed Charcoal Canister...What To Do With Vapor Line?
Old Jul 8, 2007 | 06:44 PM
a1320addict's Avatar
Default Removed Charcoal Canister...What To Do With Vapor Line?
What is everyone doing with the vapor line after removing the charcoal canister?
Old Jul 8, 2007 | 06:53 PM
digitalcongo's Avatar
Default Re: Removed Charcoal Canister...What To Do With Vapor Line? (a1320addict)
well...why did you remove the canister...?
dont block off the vent pipe to the gas tank...
run it pre-turbo if that is the case
or i guess just leave it open
if you are using a catchcan that utilizes vacuum...thats another good place...
the fuel vapors will combine well with the hydrocarbons
if you are still n/a i would put the canister back in and use it...
or connect the vent pipe strait to the intake
Old Jul 8, 2007 | 07:19 PM
Default Re: Removed Charcoal Canister...What To Do With Vapor Line? (digitalcongo)
Car is being built to compete in SFWD.
Have no use for evap purge, or the means to incorporate it if I wanted to.
I'm tentatively planning on kicking the pipe down a bit and letting it vent before the firewall; sound good?
Old Jul 8, 2007 | 07:45 PM
personally i would say possible fire hazard...
sparks from road...etc...
wait for someone else to chime in
but yes...connecting the vent pipe strait to intake would cause a vac leak condition...
i guess i just never understood the decisive removal of it...even in race cars...
its not like the canister weighs much
Old Jul 9, 2007 | 12:14 AM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalcongo &raquo;</TD></TR><TR><TD CLASS="quote">personally i would say possible fire hazard...
its not like the canister weighs much</TD></TR></TABLE>
OMG are you serious it is not about weight!
Your going to seriously tell me venting gas vapor back into your expensive built engine is ok?
Old Jul 9, 2007 | 04:21 AM
Default Re: Removed Charcoal Canister...What To Do With Vapor Line? (richard7968)
like i said...
its a concept i do not understand
does it throw off a/f that much...?
Old Jul 9, 2007 | 09:25 AM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalcongo &raquo;</TD></TR><TR><TD CLASS="quote">like i said...
does it throw off a/f that much...?</TD></TR></TABLE>
Pm'd!
Old Jul 15, 2007 | 04:43 AM
viskii420's Avatar
bumppp
Old Jul 15, 2007 | 05:04 AM
Default Re: (viskii420)
unless you are chipped with good tuning software or standalone...
then you cannot disable the purge valve
there is no serious performance loss from using it
hook it back up...or buy the parts you need to do so for $10...
my .02
your car runs on gas...
whatever that douchenozzle is trying to say that fuel vapor is bad for your car
atomized fuel is about the best thing you could possibly give your car
not that the amounts delivered by the vapor from your tank/canister is going to alter anything that severely...
it will not !!!
Old Jul 15, 2007 | 07:11 AM
viskii420's Avatar
does it hurt if ur are boosted when AFR is critical on high boost? and EVAP solenoid releases this gases in IM.?
Old Jul 15, 2007 | 06:53 PM
slowcivic2k's Avatar
All I would do is put a one-way check valve on it so when the tank builds pressure, it will open up, route it to where-ever you like. Make sure your gas cap is good though, air needs to get in the tank so a vacuum does not occur.
Old Jul 15, 2007 | 08:26 PM
Richard...'s Avatar
Default Re: (digitalcongo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalcongo &raquo;</TD></TR><TR><TD CLASS="quote">douchenozzle
lol what the hell is that suppose to be aimed at?
Old Jul 15, 2007 | 08:32 PM
Default Re: (richard7968)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 &raquo;</TD></TR><TR><TD CLASS="quote">
well it supposed to be aimed at a females extremities as far as I know.... but who am I to say?
Old Jul 15, 2007 | 08:37 PM
Richard...'s Avatar
Default Re: (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">
well it supposed to be aimed at a females extremities as far as I know.... but who am I to say?</TD></TR></TABLE>
Dear god!
We have a comedian on the forum!
Old Jul 15, 2007 | 08:38 PM
Well you asked for it. XD
Old Jul 15, 2007 | 08:43 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Well you asked for it. XD</TD></TR></TABLE>
Yes I suppose I did, didn’t I?
However the reason asking was because i thought i already cleared all this rubbish up with digitalcongo via PM
it would however seem his insult was aimed at me hence i was sarcastically asking!
Old Jul 15, 2007 | 09:48 PM
who would put fuel in their internal combustion engine !!!
that will break its whole purpose of sitting in the dark....all shiny....
oh noes...not fuel !!!...NOOOOOOOOOOOOOOOOOOOOOOOO!!!!
OH MY GOD
DID YOU HEAR WHAT THAT MAN JUST SAID OVER THERE
HE SAID HE WANTED TO PUT FUEL VAPOR IN HIS ENGINE !!!
NOT FUEL VAPOR .... nOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!
heres a coupe check valves on ebay
http://cgi.ebay.com/Check-Valv...wItem
http://cgi.ebay.com/Plastic-Ch...wItem
Modified by digitalcongo at 2:03 AM 7/16/2007
Old Jul 15, 2007 | 10:27 PM
Richard...'s Avatar
Default Re:
LOL
Old Jul 16, 2007 | 07:54 PM
viskii420's Avatar
? does this fix the problem of the canister?
Old Jul 16, 2007 | 08:21 PM
thats for eliminating the pcv setup for boosted applications...
which is a must-do for turbo applications
but you 'could' also run the vent pipe to there too...
but see the filter on top...thats for an open.air setup
many people run that way...
but another method is to use vacuum from in front of the turbo inlet
which lowers crankcase pressure...a desired effect...
the problem with vacuum setups is you tend to dirty your turbo with crankcase blowby...etc...
but if you build a nice filtration setup...and maintain vacuum...
...then you are helping your motor more than a open.air setup
Old Jul 16, 2007 | 10:26 PM
viskii420's Avatar
Thats A Canton Breather catch canister, specific for the canister
Old Jul 17, 2007 | 06:00 AM
specific for the ???what???
Old Jul 17, 2007 | 06:27 AM
viskii420's Avatar
i'm trying to remove the Charcoal Canister my self but i want to do it the safe way. Instead letting the pipe bent open air would it be better connected to the catch canister?
Old Jul 17, 2007 | 07:47 AM
a little better...
Old Jul 17, 2007 | 08:09 AM
viskii420's Avatar
I'm building boost application. what is the best way of doing this?
