your thoughts on skunk 2 ITR.......
Old Jun 7, 2002 | 09:56 PM
baonest's Avatar
Default your thoughts on skunk 2 ITR.......
skunk 2 valves, valve springs, retainers, cams, and cam gears all on ITR head...... what do u guys think.. how much better that stock is this if it is at all? also what type of intake manifold should i go with..
thanx fer yer input
Old Jun 7, 2002 | 10:03 PM
SurferX's Avatar
Default Re: your thoughts on skunk 2 ITR....... (baonest)
What stage cams?
Old Jun 7, 2002 | 10:12 PM
comptechgsr's Avatar
Default Re: your thoughts on skunk 2 ITR....... (SurferX)
ur stock itm should be fine.........
i dont trust any moving parts made by skunk
Old Jun 7, 2002 | 10:38 PM
FAST94GSR's Avatar
New User
Default Re: your thoughts on skunk 2 ITR....... (3800RPM Redline)
you obviously don't know anything about skunk then..
All Skunk products work. Last I checked they had the fastest all motor Integra not too mention the fastest all motor car period running a 10.6 They must know something.
Old Jun 7, 2002 | 11:44 PM
SurferX's Avatar
Default Re: your thoughts on skunk 2 ITR....... (FAST94GSR)
You think they are using the same off the shelf stuff that they are selling us? Haha no way in hell.
I don't know the specific setup on the Skunk car, but on the AEM turbo car the only things AEM are cam gears and a piece of a chopped up CAI. I know the Skunk car was using a HyTech header at one point but not anymore. I think the name on the car doesn't really show who put what into it. I'd hate to use NASCAR as an example but it probably works the same way.
Regaurdless, I've heard good things about most Skunk2 products. The Stage 2 cams seem like a good moderate upgrade comparible to the Toda B's as long as you have the needed upgrades to go with it.
EDIT:
Skunk2 Stage 2
INTAKE lift- 12.07 mm, duration 265 @ 1mm
EXHAUST lift - 11.6 mm, duration 256 @ 1mm
Thanks to Master Tuan for talking to Mr. Hsu and getting the cam specs info.
[Modified by SurferX, 12:50 AM 6/8/2002]
Old Jun 8, 2002 | 02:08 AM
which skunk2 parts do u have on your car........and for how long?
Old Jun 8, 2002 | 06:18 AM
00MRSi's Avatar
I agree, Skunk2 cams seems to work quite well. As always tuning is key. Also, I think the stock ITR IM should be more than sufficient. The Skunk2 IM is almost identical to the stock ITR IM.
Old Jun 8, 2002 | 06:41 AM
EagleR's Avatar
Default Re: your thoughts on skunk 2 ITR....... (00MRSi)
Skunk 2 cams are good for the dollars that they cost...theres better...but they'll work.
Old Jun 8, 2002 | 07:26 AM
baonest's Avatar
Default Re: your thoughts on skunk 2 ITR....... (EagleR)
i was thinking about stage 2's... but i might go with stage one cuz im not gonna be revvin up in the 9K's..
now bout with a built bottom end... stage 2 or 1??
thanx-- so i might just stick with stock ITR valvetraine even though they cost about the same as the skunk2... i have a brand new head, nothing on it. i probably should of mentioned it..
Supafranc
Nov 9, 2008 06:58 AM
Simmerman
May 10, 2006 01:46 PM
TeamDOHCside
Sep 5, 2005 02:10 AM
speedyR
Feb 4, 2004 11:31 AM
Weslay
Jan 10, 2002 05:59 AM
