My time with my no longer usable slicks!!!
Im sure it would have been a 12s pass but my old slicks were maybe at the end of their time with the bad 60foot i got there!!!
I1-->2.025
I2-->8.345
I3-->13.005
MPH-->108.8
I need to save money and bu new slicks soon!!! I should be in the 1.6-1.7 range not 2.0
I1-->2.025
I2-->8.345
I3-->13.005
MPH-->108.8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM »</TD></TR><TR><TD CLASS="quote">Im sure it would have been a 12s pass but my old slicks were maybe at the end of their time with the bad 60foot i got there!!!
I1-->2.025
I2-->8.345
I3-->13.005
MPH-->108.8
For your power/weight, sounds about right. What size slicks/rims?
I1-->2.025
I2-->8.345
I3-->13.005
MPH-->108.8
</TD></TR></TABLE>For your power/weight, sounds about right. What size slicks/rims?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinz »</TD></TR><TR><TD CLASS="quote">
For your power/weight, sounds about right. What size slicks/rims?</TD></TR></TABLE>
22/8/15...215whp/135wtq in a 2440pounds car with me in it!!!
I have the same problem 13.0@107.1 mph with 1.9 60 feet... Wheels 9x22x13 Honda OEM rims 13x5
I have to change the rims and try to get 1.6-1.7 in 60' and welcom 12'seconds league
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 »</TD></TR><TR><TD CLASS="quote">whats the tire pressure your running?</TD></TR></TABLE>
Between 7 and 10psi!!! I just wanna know if with a 1.7-1.8 i can cut a 12second pass??? Ive done 13.0 and 13.1 with my street tire on 2.0-2.1 60footer...
your 1/4 ET is about right considering you did an 8.3 1/8th...your mph is a bit high for your ET...get the most out of your 60' and 330' times and you can be a mid/high 12 car...
traction bar?
traction bar?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">your 1/4 ET is about right considering you did an 8.3 1/8th...your mph is a bit high for your ET...get the most out of your 60' and 330' times and you can be a mid/high 12 car...
traction bar?</TD></TR></TABLE>
Thanks i just wanna see some 12s
But im sure the car run constant 12.5-12.6 the power is there...i still wish to get a 1.6 out of the box
well your almost there, keep trying and youll make it....but thats a pretty big jump to 1.6 considering your besting a 2.0 60' right now...but at least you know where you stand and can make improvments from here on...
stock suspension?
traction bar?
stock suspension?
traction bar?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">well your almost there, keep trying and youll make it....but thats a pretty big jump to 1.6 considering your besting a 2.0 60' right now...but at least you know where you stand and can make improvments from here on...
stock suspension?
traction bar?
Last yeah the week-end after i had buy the slicks i was able to cut 1.7-1.8 all day long...its just that i need to buy a new pair because mine are just finish
stock suspension?
traction bar?
With 108 mph, you should have no problem digging into the mid 12's. I trap somewhere in the 109 range the majority of the time and have a stack of 12.50's with mid/low 1.70's. Several 12.40's as well on good nights. You have the power, all you need is the traction now.
stock suspension?
traction bar?
In my cases i have traction bars,lsd and presure of the tires was 15 psi. But my rims are so tiny for the tires...
60' -----> 1.9
330'------> 5.58
1/8------->8.48
1/4--------> 13.08
107.1 mph
stock suspension?
traction bar?
60' -----> 1.9
330'------> 5.58
1/8------->8.48
1/4--------> 13.08
107.1 mph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing »</TD></TR><TR><TD CLASS="quote">With 108 mph, you should have no problem digging into the mid 12's. I trap somewhere in the 109 range the majority of the time and have a stack of 12.50's with mid/low 1.70's. Several 12.40's as well on good nights. You have the power, all you need is the traction now.</TD></TR></TABLE>
Thanks you give me hope
For suspension, i have KYB shocks on eibach pro-kit coil over...no traction bar and no LSD for know
I have it so i just need to book an appointment to make the LSD transfer in my casing
Hope to be back on the track by august
I have some other pass at 13.0-13.1 and one with a 8.1 at the 1/8 at 85.6mph but didnt manage to pull a 12s
Grrrrrr i hate my slicks
DriveSlowHomie
May 10, 2005 01:20 PM
Do you guys think some 20/8/14 would be better??? Im sure the car can pull some mid 12s easy with the right combo
