Tach not reading properly, bounces around and rests at zero a lot. <VIDEO>
Old Jul 8, 2007 | 11:43 AM
j0nb0y22's Avatar
Default Tach not reading properly, bounces around and rests at zero a lot. <VIDEO>
http://s195.photobucket.com/al...0.flv
It started out working well then after a drive it seemed to do worse and worse. Seems like a bad ground but I don't really know where to trace it back to. I have tried two other clusters so I have eliminated that as a variable. Also, it may be related or unrelated but my speedo is not working either, this was also confirmed with both other clusters. Thanks for any help!
Old Jul 8, 2007 | 12:39 PM
j0nb0y22's Avatar
Default Re: Tach not reading properly, bounces around and rests at zero a lot. <VIDEO> (j0nb0y22)
Any idea where I would check for a bad ground? Is it behind the cluster or somewhere else behind the dash?
Old Jul 8, 2007 | 03:08 PM
j0nb0y22's Avatar
up
Old Jul 8, 2007 | 03:10 PM
Dramier's Avatar
Year model, trim level, etc?
What did you do prior to this? Change ignitions components like distributor or anything? Install a white face guage setup?
Old Jul 8, 2007 | 03:18 PM
j0nb0y22's Avatar
lol no mad tyte indiglo gauges here. I recently purchased the car so I can't be sure when it started but it is a 94 Civic hatch. I swapped the cluster when I first purchased the car (it did not have a tach) and thats when I noticed the tach problem. I thought it may be a problem with that cluster so I purchased another one from an Integra LS... it did the same thing.
Old Jul 8, 2007 | 03:19 PM
broketuner-Sol_Si's Avatar
Default Re: Tach not reading properly, bounces around and rests at zero a lot. <VIDEO> (Dramier)
LOOKS like it may be a dizzy problem(mine did something similar...would bounce between 3-5 k while holding gas pedal steady....got a dizzy from distributor king for fairly cheap, car runs much smoother and tach problem is gone)
Old Jul 8, 2007 | 03:37 PM
j0nb0y22's Avatar
It idles just fine, its just the tach that bounces around not the rpms... would this still be caused by the dizzy?
Old Jul 9, 2007 | 07:09 AM
j0nb0y22's Avatar
up
Old Jul 9, 2007 | 07:46 AM
kleanlscivic's Avatar
have you tried a new VSS (speed sensor)?
Old Jul 9, 2007 | 07:49 AM
PhantomLord's Avatar
Default Re: Tach not reading properly, bounces around and rests at zero a lot. <VIDEO> (kleanlscivic)
VSS
Old Jul 9, 2007 | 08:44 AM
Luserkid's Avatar
Default Re: Tach not reading properly, bounces around and rests at zero a lot. <VIDEO> (PhantomLord)
VSS does not give an RPM signal, so how could it be the VSS?
RPM signal comes straight from ECU which comes from the ignitor (in the distributor)(96-00) or straight from the ignitor (92-95). With that being said its only 2 things that could be causing this. 1. bad RPM signal wire or 2. Bad ignitor.
Old Jul 9, 2007 | 02:03 PM
Default Re: Tach not reading properly, bounces around and rests at zero a lot. <VIDEO> (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">VSS does not give an RPM signal, so how could it be the VSS?
RPM signal comes straight from ECU which comes from the ignitor (in the distributor)(96-00) or straight from the ignitor (92-95). With that being said its only 2 things that could be causing this. 1. bad RPM signal wire or 2. Bad ignitor. </TD></TR></TABLE>
i dont know but mine was acting up when i did my ls swap and replaced it and mine works fine???? just trying to give some info
Old Jul 9, 2007 | 03:15 PM
Dramier's Avatar
Truth. VSS has nothing to do with RPM.
VSS is a pulsed 5V signal anyway.
Try taking a direct RPM reading off the distributor with a multimeter and see if it's right. If not, then it's the dizzy, if it's right, start tracing the wire to the cluster.
dsturch1
Jan 14, 2007 08:28 PM
importboi22
May 31, 2004 09:54 PM
ap1driver
Nov 13, 2003 09:42 AM
CLBrackin
13
Jan 6, 2003 05:45 AM
