transmission leak
Old Jul 8, 2007 | 09:51 AM
89civicsedan's Avatar
Default transmission leak
i have a 1993 civic lx and the transmission looks like its leaking by where the axle slips into the transmission, is there a seal there that could have went bad? It is a 5 speed manual transmission.
Old Jul 8, 2007 | 10:21 AM
Ramma's Avatar
yes, its called an axle seal. Pretty easy to replace, just pull the axle, pull the old one out and put a new one in.
Old Jul 8, 2007 | 11:09 AM
96cxhatch17's Avatar
Default Re: (Ramma)
bump
Old Jul 8, 2007 | 11:18 AM
ke98248's Avatar
Default Re: (96cxhatch17)
be careful when you pull out the axle to not damage it. You don't want to pull on the cv axle itself, but you want to use a small pry bar to break it loose (gently). There's plenty of DIY's on H-T if you need more info.
Quit post whoring 96cxhatch17!
Old Jul 8, 2007 | 12:13 PM
Default Re: (ke98248)
ok, thanks alot
Quada
Transmission & Drivetrain
Jul 1, 2010 10:44 PM
project91crxsi
Aug 21, 2009 05:56 PM
driveslow
19
Mar 5, 2009 07:03 PM
WPeters
Apr 30, 2008 07:19 AM
phuckinilltegie
Oct 8, 2003 01:56 PM
