help with parts
Old Jun 7, 2002 | 08:44 PM
swank's Avatar
Default help with parts
i am about to buy an 94-95 LS. overtime i would like to make it turbo. what parts (from the very start) should i get to make my car faster and run better, and when i get turbo, not have to replace mods. i no that you need at least 2.5 exhaust. and when you give parts, please state in your opinion what the best brand is. thank you for your help, i am just starting out. thanks
Old Jun 7, 2002 | 10:49 PM
Sh!+F@ce's Avatar
Default Re: help with parts (swank)
any intake or headers you put on will probably become worthless once you purchase the turbo system. just save your cash and buy the turbo then invest in other parts to assist it.
Old Jun 8, 2002 | 02:49 AM
AzN_Flava's Avatar
well if you are going to go turbo... most n/a parts will not help you...
it would be best to save your money...
this probably isn't the answer you want.. but its true...
headers no needed intake no need exhaust.. either you gettinga turbo one from the start or don't bother...
gearing.. if you go turbo.. your ls is fine.. no need to switch...
just save money.. and piece your turbo together slowly...
welcome to honda-tech
Old Jun 8, 2002 | 03:30 AM
97hb's Avatar
Get ignition, and fuel upgrades Maybe a carbon fiber hood.
Old Jun 8, 2002 | 01:29 PM
EagleR's Avatar
Default Re: help with parts (97hb)
don't do any Internal to you decide on turbo...JDM size exhaust at the least...that will work for NA and Mild turbo apps...
Old Jun 8, 2002 | 03:06 PM
threatcon13's Avatar
New User
Default Re: help with parts (EagleR)
if you know for sure you are going turbo..dont waste the money on practically anything. because you will need a 3" exhaust for optimal gains w/ turbo...regardless if it is mild or wild. just upgrade clutch/flywheel and suspension to handle the turbo.
Old Jun 9, 2002 | 02:24 PM
LODOSS's Avatar
Default Re: help with parts (ALLMOTORDC2)
i would go ahead and get a high flow cat.. amybe 2 1/2 o r 3 inch and then maybe a exhuast that compliments to the size of the cat.
SilverEK96
Texas -OK -LA (Sales)
Jan 9, 2018 07:41 PM
