HELP!i think im running rich bad mpg.
Old Jul 7, 2007 | 11:33 PM
BB1LOViN's Avatar
Default HELP!i think im running rich bad mpg.
i calculated my MPG and im getting 16mpg. on my H22A1.
do i need a tune up?or should this be normal for a 94' car. the factory specs say 22mpg :X
or any other ideas to check for?
Old Jul 7, 2007 | 11:35 PM
prelude_93vtec's Avatar
Default Re: HELP!i think im running rich bad mpg. (BB1LOViN)
do you race it or drive normally? i think you need a tune up and check TAP ( tire air pressure)
Old Jul 7, 2007 | 11:39 PM
98vtec's Avatar
moderator emeritus
any check engine lights?
how long has it been since you changed:
fuel filter
dizzy cap
rotor
plugs
plug wires
Old Jul 7, 2007 | 11:43 PM
BB1LOViN's Avatar
Default Re: HELP!i think im running rich bad mpg. (prelude_93vtec)
i always check the tire pressure and its all at a even 40psi.
as for racing i pop VTEC maybe 3 or 4 times but not usually.
could it also be that im usually driving in 4th?
im gonna try 5th in street driving and see if that helps.
Old Jul 7, 2007 | 11:45 PM
BB1LOViN's Avatar
Default Re: HELP!i think im running rich bad mpg. (98vtec)
thanks ill check those.
fuel filter was changed less than 1k ago.
dizzy cap?
as for everything else they all seem fine.
and nope no CHECK ENGINE LIGHT.. the engine ONLY has about 60k original miles.
Old Jul 7, 2007 | 11:46 PM
lol ya try drivin on 5th. thats prolly your problem.
Old Jul 7, 2007 | 11:50 PM
BB1LOViN's Avatar
"Im the youngest guy to own a prelude at 15 years old "
lol PROPS to ya. i got my BB1 3 months after i turned 16 haha
Old Jul 7, 2007 | 11:57 PM
no1knows908's Avatar
Yea I'm having the same problem with my H23. Horrible mileage and lots of black soot from the exhaust. No CELs and I have done a complete tune up and just changed the plugs AGAIN. I might get a new O2 sensor since its still under warranty. I am suspecting a bad fuel pressure regulator but I don't know where to hook up the tester. All the ones I've seen have a female fitting and I thought it has to connect to the female service bolt hole on the fuel rail.
Old Jul 8, 2007 | 09:46 AM
NNV's Avatar
NNV
Check your map sensor connections, the little vac line that runs from the manifold to the sensor via the hard metal lines have a tendency to wear out. Mine did that for a while until i found out there was a tiny little rip in the soft vac line.
Old Jul 8, 2007 | 01:09 PM
DCxMagus's Avatar
Default Re: (NNV)
open your dizzy and check the cap and rotor leads probably corroded and needs to be replaced.
Old Jul 8, 2007 | 07:29 PM
Default Re: (DCxMagus)
Cap and rotor are fairly new and I checked it a few days ago. The map sensor vacuum line is a good idea. Is there any way to check it besides a visual inspection? Should I monitor the vacuum with a gauge? If so what should the vacuum be on the map line at idle?
Old Jul 8, 2007 | 08:43 PM
BB1LOViN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCxMagus &raquo;</TD></TR><TR><TD CLASS="quote">open your dizzy and check the cap and rotor leads probably corroded and needs to be replaced.
sorry but what's a "DIZZY"?
Old Jul 8, 2007 | 08:50 PM
Default Re: (BB1LOViN)
He means take off your distributor cap and inspect the connections on the cap and the blade of the ignition rotor for corrosion or wear.
Old Jul 9, 2007 | 06:32 AM
shaylude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB1LOViN &raquo;</TD></TR><TR><TD CLASS="quote">"Im the youngest guy to own a prelude at 15 years old "
lol PROPS to ya. i got my BB1 3 months after i turned 16 haha</TD></TR></TABLE>
nope, i got mine when i was 14
Even though i couldn't drive it. it was minnnnne
Old Jul 9, 2007 | 06:34 AM
lenn's Avatar
Typically changing the primary O2 sensor has had the greatest effect on my gas milage. I was getting about 25MPG ong long trips, changed the O2 sensor and it went up to around 31MPG.
I recently changed my O2 sensor again last week, long story, but I was getting around 21MPG around town. I currently believe I should be seeing around 28-30 (havent filled the tank yet, but I am seeing much more milage out of my current fuel usage).
I was not throwing any CELs in either case, but decided to change the O2 sensor anyway. A dying O2 sensor may not trip a CEL, and will cause the car to perform poorly (hesitation, stumbling, poor gas milage)
Old Jul 9, 2007 | 08:34 AM
Default Re: (lenn)
I'm changing the o2 sensor for the third time in a year. I guess thast what you get for using bosh sensors.
Old Jul 9, 2007 | 05:08 PM
lude98SH's Avatar
Default Re: (no1knows908)
bad coolant temp sensor can cause a rich condition. Also any type of restriction in the air intake system may also cause a rich condition. The computer will compensate for the lack of air as best it can but performance or gas milage may be reduced in the process. So in reality the car may drive fine but get bad gas milage or not pass emissions.
Old Jul 9, 2007 | 05:17 PM
russlan44's Avatar
Default Re: (lude98SH)
i get 22mpg and i think that not enough thinking of a civic for DD
OoEKCoupeoO
Feb 18, 2014 05:44 PM
brideezy
Apr 28, 2010 09:03 AM
BB1LOViN
Jul 19, 2009 12:04 PM
rogandrach
Jun 22, 2009 03:40 PM
RadRonny
Dec 15, 2004 12:34 PM
