What do i need from a 99-00 si for a rear disc conversion on a 99 dx
What do i need from a 99-00 si for a rear disc conversion on a 99 dx? There is a wrecked si in a junkyard near me and I'm thinking of going by to pickup the rear disc assembly, but I'm not sure exactly what I will need. Can anyone give me a parts list that I should pick up? Also what should I be expecting to pay for it?
Thanks in advance.
Thanks in advance.
make it easy, get both rear lower control arm assemblies and the parking brake cables. also, you will need a 40/40 porp. valve. just ask for the one off the car. getting the master cylinder isn't a bad idea either, it will help make sure you still have a good pedal feel.
Here's a link that might help...
https://honda-tech.com/zerothread?id=1625394
Your 96-00 DX Hatchback already has the same Prop Valve as the 99-00 SI... 46210-S04-902
JasonGhostz
JasonGhostz
crazyowes2000
Nov 20, 2010 02:03 PM
Bambooseven
Sep 22, 2010 03:59 PM
