Those with Boomslang (and such) type adapters for your ECU...
How did you mount all of the extra wires? Were you able to get everything back the way it was supposed to go, in reference to the ECU, ECU cover, black wire flat thing, etc?
Seems like the Boomslang left too much wire and I'm having trouble coming up with a good and safe way to mount everything while using all of the OEM hardware around the ECU. Not to mention getting the plastic kick-panel to fit back on properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjerry »</TD></TR><TR><TD CLASS="quote">Pics? Was about to order the boomslang from King. Any better fitting ones out there?</TD></TR></TABLE>
Boomslang appears to be a quality piece, but unless I'm missing something I don't see anyway to preserve all of the OEM stuff.
I'm **** about installations though.
My wires fit fine... can't even tell there is a harness there.... it's a clean and easy install compared to splicing your ECU wires, which I did before I purchased the harness...
I don't think my panel fit back on perfect, but fugg it.... its black and at your feet. You can barely tell.
I couldn't get the metal cover to fit either, so I just put the kick panel on without attaching the bottom fastener.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">I couldn't get the metal cover to fit either, so I just put the kick panel on without attaching the bottom fastener.</TD></TR></TABLE>
ER'YUP
ER'YUP
Double the harness in two so that both of the connector blocks are touching each other and tuck one end in under the ECU and fit the cover, the other connector block will be stuck out the bottom of the metal cover but it does fit and the cover goes back on perfectly, its just a matter of pushing and bending the wires until you get it all fitted into the area below the cover.
sshaikh01
26
Mar 28, 2003 07:49 PM
