4th gen edm dimmer switch? Wiring to dome light.
Old Jul 7, 2007 | 09:32 PM
jdmludeaz's Avatar
Default 4th gen edm dimmer switch? Wiring to dome light.
I know the switch on the dash is for the gauges. The only visual difference is one is flush and the other is not. I heard a rumor that the edm dimmer switch is for the dome light. Can someone help me out here.
Old Jul 7, 2007 | 10:33 PM
bboixtc's Avatar
Default Re: 4th gen edm dimmer switch? Wiring to dome light. (jdmludeaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmludeaz &raquo;</TD></TR><TR><TD CLASS="quote">I know the switch on the dash is for the gauges. The only visual difference is one is flush and the other is not. I heard a rumor that the edm dimmer switch is for the dome light. Can someone help me out here.
you were lied to.
bb4 preludes had a coin pocket holder in place of the switches on the bottom. They did not need a sunroof switch because they had no sunroofs. I have that dimmer switch right now.
Old Jul 8, 2007 | 04:41 AM
'95 BA8's Avatar
Default Re: 4th gen edm dimmer switch? Wiring to dome light. (bboixtc)
Oh well at least you got that mad tyte JDM half-mast switch , you can fit some Acuras seat heating switches into those two other slots :/
Just for looks.
Old Jul 8, 2007 | 06:33 AM
jdmludeaz's Avatar
Do you think its possible to use the switch to the dome light. I know there would have to be some kind of fabrication with the light assembly,because of the bulb.
Old Jul 8, 2007 | 07:22 PM
jdmludeaz's Avatar
Can it be wired to the dome light?
Old Jul 8, 2007 | 07:32 PM
bboixtc's Avatar
why would you want to?
Old Jul 9, 2007 | 06:44 AM
jdmludeaz's Avatar
I just think it would be a cool mod to set the mood.
Old Jul 9, 2007 | 07:07 AM
bboixtc's Avatar
i'm sure it's easy to do, get yourself a dimmer relay, wire diagram and a volt meter and play with it.
Old Jul 9, 2007 | 09:01 AM
jdmludeaz's Avatar
do you think I could use the dimmer relay from the el gauge and wire diagram?
Tank_EM2
Honda Civic (2001 - 2005)
Mar 1, 2015 04:17 AM
hust1er
Audio / Security / Video
Aug 22, 2007 11:21 AM
jdmh22a1
May 18, 2007 04:31 PM
GranadaTeg
Jan 16, 2006 08:52 PM
98TypeSH
Oct 26, 2004 01:37 PM
