jdm f22 sohc vtec
Old Jul 7, 2007 | 08:35 PM
oliberos112's Avatar
Default jdm f22 sohc vtec
does anyone know anything bout this motor. i know its a 160hp motor, but what what else? any aftermarket pieces? do i need the jdm ecu to run this or can i use the usdm? will it bolt up to the usdm tranny? anythin and everythin will help
Old Jul 7, 2007 | 08:49 PM
fastazzf22's Avatar
Default Re: jdm f22 sohc vtec (oliberos112)
its identical to the usdm motor. Will bolt to everything no problem . Ecu will work as well . Unless your not replacing the motor with the same engine . If its the same . Everything is easy peasy !! That motor isnt 160chp . Its 145chp.
wing.jai
May 18, 2009 11:34 AM
roller3804
Dec 7, 2005 07:34 AM
speedcreations
Apr 2, 2004 02:47 AM
Evil_Wizard
Jun 28, 2003 11:19 PM
