PR3 Pistons: OEM vs Nippon vs RS Machines vs Hastings
Old Jul 7, 2007 | 05:11 PM
votoms888's Avatar
Default PR3 Pistons: OEM vs Nippon vs RS Machines vs Hastings
I am looking for PR3 pistons to put in a b18a block as I am doing a non-vtec build. Other than oem, I have found a few companies who make them too. I am looking for cast pistons. OEM are the most expensive of the four choices I have. Which ones do you recommend.
Oem: about $250usd including wrist pins and rings
Nippon Racing: $132.95usd including wrist pins and rings
RS Machines: $149.99 including wrist pins and rings
Hastings: $139.99 including rings (not sure if wrist pins are included) i hope so
Please post your experiences and comments too.
Old Jul 8, 2007 | 07:57 PM
EKB18BPR3's Avatar
Default Re: PR3 Pistons: OEM vs Nippon vs RS Machines vs Hastings (votoms888)
look at my sig. i have nippon pr3 in my b18b setup. i just installed it on 7/7/07 and went smooth. i broke it in for the first 20 miles and drove hard the next 200 miles. what ever companie u go with the pr3 will be a very nice add on. u have 135 posts so i dunno if u knew this or not but just wanted to remind u that u do need to use the rods from the b18b/a motor. have fun with ur setup.
Old Jul 8, 2007 | 08:20 PM
dude_123's Avatar
You can't go wrong with either brands, because all those piston brand -except oem, you listed are provided by NOA (Nippon of America). RS Machines uses Hasting Rings so Hasting basically sells the same pistons as RS.
Old Jul 8, 2007 | 08:44 PM
votoms888's Avatar
Default Re: PR3 Pistons: OEM vs Nippon vs RS Machines vs Hastings (EKB18BPR3)
Yup, got that covered. I have arias forged LS rods.
Old Jul 8, 2007 | 08:45 PM
votoms888's Avatar
Do the RS Machines pistons come with wrist pins? I don't see anywhere in their adds that they do. They only specify rings.
Old Jul 8, 2007 | 08:48 PM
votoms888's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKB18BPR3 &raquo;</TD></TR><TR><TD CLASS="quote">look at my sig. i have nippon pr3 in my b18b setup. i just installed it on 7/7/07 and went smooth. i broke it in for the first 20 miles and drove hard the next 200 miles. what ever companie u go with the pr3 will be a very nice add on. u have 135 posts so i dunno if u knew this or not but just wanted to remind u that u do need to use the rods from the b18b/a motor. have fun with ur setup. </TD></TR></TABLE>
Am I correct in assuming that you don't need to machine LS rods?
What are you putting down with your setup?
Old Jul 8, 2007 | 09:02 PM
dude_123's Avatar
Default Re: (votoms888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by votoms888 &raquo;</TD></TR><TR><TD CLASS="quote">Do the RS Machines pistons come with wrist pins? I don't see anywhere in their adds that they do. They only specify rings.</TD></TR></TABLE>
Yes, they do come with wrist pins and rings.
Old Jul 9, 2007 | 02:07 PM
b20vtech's Avatar
all those brands are good.... used all of em before, no problem...
Old Jul 9, 2007 | 02:39 PM
Furyof4's Avatar
Default Re: PR3 Pistons: OEM vs Nippon vs RS Machines vs Hastings (b20vtech)
If your using forged rods, you will have to get the pistons machined for wrist pin locks. Those aftermarket rods have floating pin bushings and the oem rods are press fit.
Old Jul 9, 2007 | 03:00 PM
SiB16A's Avatar
Default Re: PR3 Pistons: OEM vs Nippon vs RS Machines vs Hastings (Furyof4)
OEM is good, rs is good, I have nippons right now. Not sure about hastings
Old Jul 9, 2007 | 03:19 PM
EKB18BPR3's Avatar
sorry it took me so long to answer ur question...u do not need to modify the pistons to work. gsr,ctr,itr...u do thats why people gp with pr3/p30...no mods
Old Jul 9, 2007 | 05:33 PM
stumpyf4's Avatar
Got RS Machine 81.5 ITR styles. Came with wrist pins and rings. My rings were Arias'.
Old Jul 10, 2007 | 11:18 AM
votoms888's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKB18BPR3 &raquo;</TD></TR><TR><TD CLASS="quote">sorry it took me so long to answer ur question...u do not need to modify the pistons to work. gsr,ctr,itr...u do thats why people gp with pr3/p30...no mods</TD></TR></TABLE>
I have a set of Arias forged rods that I will be using. The guy that I bought them from said that they are for LS and don't require anything special to use them with PR3 pistons. Does this make sense?
Old Jul 25, 2007 | 06:54 AM
stumpyf4's Avatar
Don't think they'll be plug and play with OEM style pistons. I have no experience with these rods but think they would made for aftermarket forged pistons with floating wrist pin.
Give Arias a call or email and ask them to verify.
Old Jul 25, 2007 | 06:55 AM
del_slow420's Avatar
if your useing aftermarket forged rods you need to either run forged pistons or else get your pistons machined to accept circlips
Old Jul 26, 2007 | 06:51 AM
drift4jesus's Avatar
Default Re: PR3 Pistons: OEM vs Nippon vs RS Machines vs Hastings (del_slow420)
Or get the small ends of the rods rebushed so they will work as press fit.
Old Aug 15, 2007 | 04:36 PM
DonF's Avatar
Default Re: PR3 Pistons: OEM vs Nippon vs RS Machines vs Hastings (drift4jesus)
You cannot use pressed pins in a bronze bushing. God, I hate bad info.
89hybrid
Nov 18, 2014 03:02 PM
b18bEKcoupe
12
Jul 15, 2007 10:46 AM
92integraVTECgsr
26
Feb 15, 2007 03:06 PM
psegs80
Oct 22, 2005 03:50 PM
fukaintmuven
Mar 12, 2003 02:28 AM
