penzoil synchromesh
Old Jul 7, 2007 | 03:53 PM
Bulli Kid's Avatar
Default penzoil synchromesh
bout 2 qt's. just wondering if its ok to use in my 95 dx because it said its not intended for all manual transmissions. thaks
Old Jul 7, 2007 | 04:07 PM
philosofy1's Avatar
Default Re: penzoil synchromesh (Bulli Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulli Kid &raquo;</TD></TR><TR><TD CLASS="quote">bout 2 qt's. just wondering if its ok to use in my 95 dx because it said its not intended for all manual transmissions. thaks</TD></TR></TABLE>
if it says that it is not intended for all transmissions, then why ask to use it?
Honda MTF, that's the only MTF my B16A sees.
Old Jul 7, 2007 | 05:19 PM
Targa250R's Avatar
be professional
Yes, it's fine.
I've used 10w-30 engine oil, GM Synchromesh Friction Modified, Pennzoil/GM Synchromesh, BG SyncroShift, and Honda MTF (both the old and the new formulations) in the various Honda transmissions I've had. They all work fine. The only fluid I didn't like was the engine oil, because it made shifts feel notchy and rough.
Just whatever you do, make sure you put enough oil in. Low transmission oil levels are the main cause of input shaft bearing failure. Change it every 15,000 miles or every 3 oil changes, and remember to refill it whenever changing axles.
Old Jul 7, 2007 | 05:23 PM
trrbl1bmx's Avatar
Default Re: penzoil synchromesh (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, it's fine.
Just whatever you do, make sure you put enough oil in. Low transmission oil levels are the main cause of input shaft bearing failure. Change it every 15,000 miles or every 3 oil changes, and remember to refill it whenever changing axles.</TD></TR></TABLE>
This thread is closed! Thank you come again!
Old Jul 7, 2007 | 07:02 PM
Bulli Kid's Avatar
Default Re: penzoil synchromesh (p00n)
stock fluid was in the tranny since 95 and a ton of miles. this is the first timeits been changed. but i didnt think i would have to change it every 3 oil changes tho.
Old Jul 7, 2007 | 07:09 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulli Kid &raquo;</TD></TR><TR><TD CLASS="quote">stock fluid was in the tranny since 95 and a ton of miles. this is the first timeits been changed.</TD></TR></TABLE>
That is awful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">but i didnt think i would have to change it every 3 oil changes tho. </TD></TR></TABLE>
3x 5000-mile oil change intervals = 15,000 miles.
Old Jul 7, 2007 | 08:00 PM
blk92_d16's Avatar
I've used it, and OEM...and I'd say OEM is still superior. But it's alright.
Old Jul 7, 2007 | 08:20 PM
Targa250R's Avatar
be professional
Default Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 &raquo;</TD></TR><TR><TD CLASS="quote">I've used it, and OEM...and I'd say OEM is still superior.</TD></TR></TABLE>
Would you like to evaluate?
Nicks95GSR
Jan 10, 2008 09:56 AM
B-CRX
Nov 16, 2006 01:44 PM
CAJUNC4
Honda S2000
17
Jun 29, 2005 10:16 PM
madswapper
Mar 16, 2005 08:40 PM
return_2020
Nov 22, 2004 06:31 PM
