help itr gauge cluster isnt working
Old Jul 7, 2007 | 01:26 PM
Downz's Avatar
Default help itr gauge cluster isnt working
a friend of mine just bought a new itr cluster for his 01 itr. and now the cluster doesnt work. so we were guessing it came out of and older itr like 97 98. we tried using a 99 ls cluster but now luck either. the gauges keep reading the same thing that the car is overheating, which its not and that the gas tank is full, which its not. so do i need to find a 2000 - 2001 cluster?
thanks guys
Old Jul 7, 2007 | 01:49 PM
Circuit Star-29's Avatar
Default Re: help itr gauge cluster isnt working (downs1824)
If the back of your cluster looks like this, then you need to change out the green film on the back for the green film that can be removed from your friend's stock '01 DC cluster.
This cluster is 94-97 spec and you're friend's system needs the 98+ spec cluster.
Just remove all of the bulbs and screws from the back and you're good. Replacing is the reverse.
Modified by Circuit Star-29 at 3:00 PM 7/7/2007
Old Jul 7, 2007 | 01:51 PM
totsie7944's Avatar
Default Re: help itr gauge cluster isnt working (Circuit Star-29)
interesting info....never heard of doing that before.
Old Jul 7, 2007 | 01:59 PM
Downz's Avatar
yo Circuit Star-29 you the MAN thanks bro.
Old Jul 7, 2007 | 02:00 PM
Downz's Avatar
Default Re: help itr gauge cluster isnt working (totsie7944)
He doesnt have a cluster in the car they stole it. So i got a 99 ls one and tried just to replace it to see if that would work and the same problem happened, he was saying that same thing that you posted that we needed to change the green film on the rear but we didnt we just replaced clusters. Would the switching of the film be diff. than just changing the clusters?
Old Jul 7, 2007 | 04:57 PM
Downz's Avatar
i just installed a usdm ITR gauge cluster into my 01 ITR and after i was done i notice that my gas gauge went pass "F" but my main concern is in when i use my turn signals the rpm needle starts bouncin up and down as if it was hitting the rev limiter...can anyone help me out with this problem...I've search but didnt really find anything about the needle. bouncing problem! The real problem is that i cannot change the circuit board (green film) because i dont have the original cluster. It was stolen, Can i change around pins? What can i do need help asap! Thanks
Old Jul 7, 2007 | 07:51 PM
WickedKP's Avatar
Default Re: (downs1824)
Little bit more info would help.
1) the year of the type r ?
2) does the cluster have a immobilzer icon ?
3) when the itr was recovered was the cluster harness cut ?
4) what kinda damge was done to the car?
Old Jul 8, 2007 | 12:21 AM
It sounds like you have a pretty major wiring issue...
Old Jul 8, 2007 | 12:23 AM
Doostur's Avatar
Never heard of replacing the green circuitry before. May just work.
Old Jul 8, 2007 | 12:38 AM
Default Re: (Doostur)
Tried n trued
Old Jul 8, 2007 | 09:13 AM
94rs-turbo's Avatar
ok eith the cluste is not the right year or your wiring is not correct. Did you use the OEM 01 itr dash harness?
Old Jul 9, 2007 | 11:17 AM
Downz's Avatar
Thanks guys, i got it to work. No the harness was not cut in the 01 R. I had to repin the D plug ( 13 pin) for that of a 99 and then replaced the gauges from the ITR cluster into the 99 ls cluster( or change the green film) then it worked. Thanks again to all the people for trying to help me.
Old Jul 9, 2007 | 11:21 AM
Downz's Avatar
got it to work thanks guys
Hectorzg1
Feb 22, 2010 06:44 PM
Punkem0tion
Jul 22, 2009 04:19 PM
ohsnapzafingcu
Feb 25, 2009 07:04 PM
ShoStopR
Sep 26, 2007 06:22 PM
GuitarSlinger78
Nov 14, 2006 10:56 AM
