F.S. ECU / Throttle Body / Throttle Cables / Console / And More ! [Middle TN]
Got a few things to clean out of the trunk. I take paypal (blackdogserende@aim.com). I work alot so If I don't get back to you immediately then don't be discouraged. Also, I can ship the item to you if need be. Please reply by PM for payment.
92-95 EG Audio Console Outter Frame - $20
This is the main part of the audio console. It came with my civic when I got it and I switched back to the old console.
B16 Throttle Body - SOLD
Also came with the car. Was on an LSVTEC until an aftermarket intake was bought. The b-series throttle bodies can be used on d-series intake manifolds.
98 Honda Civic ECU P2P (Auto) A84 (Can be converted to manual) - $30
PM5 Obd-0 Ecu (Auto) (Can be converted to manual) - $10
92-96 Prelude ECU P14(Manual) (Non-VTEC) - $50
All Ecu's are unmolested.
Motorola Surfboard Cable Modem SB5120- $15
Modified by .Radical_Edward. at 10:57 AM 7/13/2007
And yes the throttle body is not coming with a map sensor. That's why it's $20 bucks. take the map off your current throttle body and use that.
bump and update - The throttle body doesn't have an idle screw either. You can easily take that off of your current one and use it.
