Got my head back...lots o'pics
Old Jun 7, 2002 | 07:05 PM
TodaSi's Avatar
Default Got my head back...lots o'pics
In case you didn't know, bent 8 intake valves when my timing belt broke. Head is all nice and clean. You can see my port and polish job I got a while back too.
And my newest modification, thanks to SGT.
Old Jun 7, 2002 | 07:37 PM
MadtownSi's Avatar
Default Re: Got my head back...lots o'pics (TodaSi)
Looks nice!!!
Are those Super Tech valves? They look like the black Nitride Super Tech valves. Are the other valves OEM? Did you go with new Ti retainers?
BTW, Chad it’s your fault that I’m not driving my Si AND you are costing me a lot of money. After reading about your mishap I decided it’s time to change a few things around with my head. I finally made the switch to Toda valve springs (should have been done from the start); going to get new valves, new Ti retainers and the PE belt should arrive soon.
[Modified by MadtownSi, 10:38 PM 6/7/2002]
Old Jun 7, 2002 | 08:12 PM
Drag R's Avatar
Head looks really good, hope that **** doesn't happen again. I got the PE belt too, can't wait to use it when i get motor back.
nick
Old Jun 7, 2002 | 08:24 PM
Jet Phi's Avatar
Default Re: Got my head back...lots o'pics (BeastyITR)
sorry to hear that bro...but that's one hella nice Head yoo got there
Old Jun 7, 2002 | 08:27 PM
acuracing's Avatar
Are you running Spec B's or C's? Did you get a PE belt also? Looks nice...
Old Jun 7, 2002 | 09:29 PM
TodaSi's Avatar
Default Re: Got my head back...lots o'pics (acuracing)
Stock ITR valves These are Portflow retainers, they look very nice, even lighter than the titanium ones I had before
Sorry about making everyone get more stuff. You don't have to if you don't want to
Gonna put the new PE belt on tomorrow...now I'm just waiting for my engine mounts so I can drop it in and get my POS running.
I'm running Spec C cams, have been for over a year now
[Modified by TodaSi, 1:31 AM 6/8/2002]
Old Jun 7, 2002 | 09:54 PM
Tweakmeister's Avatar
So what was is like without your head?
That looks very sweet. The P&P job looks like it was well done as well
Old Jun 7, 2002 | 10:09 PM
Tommy_Gunns's Avatar
What is that? Hondata gasket? What does it do and how does it increase HP?
Old Jun 8, 2002 | 02:27 AM
DutchITR1689's Avatar
Default Re: Got my head back...lots o'pics (Tommy_Gunns)
By keeping the intake manifold cool.....
Old Jun 8, 2002 | 04:01 AM
canuck-mx6's Avatar
Your port job looks a lot different from mine. Obviously thye combustion chamber is different as I have a GSR head
Yours
Mine
Yours
Mine
Yours
Mine
Are the port differences just because they are different heads?
Old Jun 8, 2002 | 07:13 AM
TodaSi's Avatar
Default Re: Got my head back...lots o'pics (canuck-mx6)
Yes, different heads. Your's looks awesome! Where did you get it done? Lietner & Bush?
Old Jun 8, 2002 | 08:20 AM
1 2 NV's Avatar
looks like ya got shafted on the P&P to me. looks awefully stock. the bottom of the intake port should b "flat" and its still the same shape it used to b bone stock. i dunno, id prolly take it to have it redone.
Old Jun 8, 2002 | 09:21 AM
canuck-mx6's Avatar
Nah, I got it done at a smaller shop, Canadian Cylinder head, but it was finessed by JUN Japan when they were investigating why my cam broke.
Old Jun 8, 2002 | 09:55 AM
GokuSSJ4's Avatar
isnt one of the most important thing on p&p the way the head would flow ? to gain power
Old Jun 8, 2002 | 10:08 AM
MadtownSi's Avatar
Stock ITR valves?? Why is one set black and the others are not?
BTW, were did you get your ITR valves and what did they run you?
[Modified by MadtownSi, 1:09 PM 6/8/2002]
Old Jun 8, 2002 | 10:34 AM
TodaSi's Avatar
Default Re: Got my head back...lots o'pics (hondaatwsu)
Different head porters, different philosophies, I guess.
I have one of the top hp producing 1.8 motors here so I guess it's working
If I were to do it again, I would not have had them take volume out of the head though (had L&B take out volume to achieve 12.0 instead of 12.6 which the pistons would have given). They milled out the area on top of the intake valves and below the exhaust valves in this picture.
Old Jun 8, 2002 | 10:59 AM
under_psi's Avatar
todaSi, is that a P72 or PR3 head?
Old Jun 8, 2002 | 11:05 AM
TodaSi's Avatar
Default Re: Got my head back...lots o'pics (T.O.tegs)
PR3-3, came on my 99 Civic Si, same head as on an ITR, minus a few small changes.
Old Jun 8, 2002 | 05:19 PM
Drag R's Avatar
Yours
Mine
Yours
Mine
Yours
Mine
Not trying to **** on your head jod(canuck-mx6) but to have the high polish look in your ports isn't good, because it doesn't give an even distridution of fuel through the ports. i.e., when the injectors spray, instead of breaking up evenly through out the ports, the fuel will just beed up and can cause u to possibly flood the chambers...
nick
Old Jun 8, 2002 | 08:54 PM
canuck-mx6's Avatar
nick
Nick, I originally had the walls semi smooth. When the head was sent out to JUN, they polished the intake port walls. I asked them about this, and apparently the head was done the same way as they do in their race cars.
They explained that the boundary layer will still be turbulent enough to promote proper combustion, but the flow is semi-laminar for maximum flow rate.
stevann
Oct 17, 2013 08:19 AM
b18cls1
Nov 2, 2008 06:56 PM
B18EG6
Jan 9, 2003 01:21 AM
Boostless97Lude
Nov 14, 2002 01:00 AM
