negative camber problems?
i lowerd my car and i have some negative camber issues and need to fix it so i dont eat through another set of tires, so do i need a camber kit, and how much will it cost, or is anybody selling a camber kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unknownracing »</TD></TR><TR><TD CLASS="quote">no i heard it helps but u still have the problem</TD></TR></TABLE>
if you are planning on getting some type of camber kit, then i suggest you get it and put it on before the alignment. that way you pay once for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unknownracing »</TD></TR><TR><TD CLASS="quote">when i put the kit on should i adjust it or will the alignment machine do that for me</TD></TR></TABLE>
no, no, and no.
if you install the kit, you then need to take it to get aligned. the technician doing the alignment will set things right, just make sure you specify you have a kit.
no, no, and no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
if you are planning on getting some type of camber kit, then i suggest you get it and put it on before the alignment. that way you pay once for it. </TD></TR></TABLE>
depending on your car and how big your wheels are...just put some washers on and it should be ok...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_racer »</TD></TR><TR><TD CLASS="quote">
depending on your car and how big your wheels are...just put some washers on and it should be ok...</TD></TR></TABLE>
washer work on the rear, not the front.
washer work on the rear, not the front.</TD></TR></TABLE>
true...
true...
yea dude, get a front camber kit. throw it on. get a hand full of washers and a few longer bolts for the rear. take it to the local repair shop and tell them your trying to achieve 0 degrees camber and theyll take care of ya
CAMBER IS WAY OFF!!!!!!! which camber kit well fix this ???????????? BEST CAMBER KIT OUT THERE??????
Kangolbrand
Suspension & Brakes
17
Mar 30, 2006 02:15 PM
